avatar_Old Wombat
Re: Airvell 1/72 Avro Winchester B.I/B.III
Started by Old Wombat, February 14, 2023, 04:34:16 PM
Went to start putting the landing gear together & found I was missing 3 pieces: found one under the box liner I have the remaining parts in (in the lid of the box) & one on the floor, where it must have dropped a couple or three weeks ago, when I dropped the box o' parts. Couldn't find the other at all, must have been consumed by the vinyl monster.
So, I scratch built a replacement part out of some 3D printing resin (a support structure from ... something) & I'll paint that up later, so I can get the landing gear done before I fit out the bomb bay.
After scratching the wheel well door opening/closing rod, I started putting the bombs together. Hopefully I'll get them finished & re-primed tomorrow this afternoon, ready for paint on Saturday.
Once the bomb bay is completed I'll fit all the fiddly little bits & hit it with another coat of clear matt.
Final jobs will be removing all the masking over the glazing; fix some of the glazing with Clearfix; rig the aerials &, then;
She'll be done & photo's shall appear via the magic of the interwebnet! :thumbsup:
Very much looking forward to this matey 👍 😀
Quote from: Wardukw-NZ on April 20, 2023, 01:25:07 PMVery much looking forward to this matey 👍 😀
So am I! :rolleyes:
As much as I'm enjoying the build, it's gone well over the self-allotted time-frame & I'm itching to do some armour :mellow: ... or a ship. :o
Quote from: Old Wombat on April 21, 2023, 12:40:38 AM
So am I! :rolleyes:
I'm having the exact same problem right now 😕
I'm weathering and pin washing the Strumpanther and I'm seriously in the mood to build something else and yeah it's armour..or a plane ..or a car ..my options are open  ;D
Landing gear fitted, minus the wheels.
Working on the bombs.
Not too long, now! ;)
Mind you, the painting of the bombs & their markings is no simple matter, as almost everything is in fractions of a millimetre! :o  :banghead:
Vulcan7
Quote from: Old Wombat on April 22, 2023, 03:03:46 AMNot too long, now! ;)
Can't wait  :thumbsup:  ....Although I am going to have to Build an Avro Manchester myself now..... Avro was just down the road from where I grew up as a kid in Greater Manchester  ;D   They used to have great airshows...I've got an old Airshow programme I must scan in & post at some point.
Quote from: Vostoc7 on April 22, 2023, 09:01:53 AM
The Woodford shows?
Vulcan7
Quote from: kitbasher on April 22, 2023, 01:32:24 PM
The Woodford shows?
Yes, did you go to any, as well?
Quote from: Vostoc7 on April 22, 2023, 01:40:41 PM
The Woodford shows?
Yep, as a kid in the 70s.  Had my first ever flight there in Piper Aztec!  Found a bunch of programmes a few weeks ago that I'd forgotten about.
Loved the Woodford shows.  Still remember Lightning F.3 noise and vertical climbs, and the USAF F-111 flyby that missed Woodford completely.  I think the passengers at Manchester Airport enjoyed seeing it zoom down the runway there.
I'm sitting here quietly freaking out over having to paint sub-0.2mm red lines on all my bombs & various sub-0.5mm lines on a few (which is nice, compared to the other :o ).
Anyway, I fitted the prop's into the nacelles yesterday, to check their fit before gluing them in, & I really have to say that Airfix were extremely intelligent with the construction of the Typhoon IB (Kit #A02041, if you're interested).
First up: The parts that I've put together for both the Winchester build & the paint monkey fit extremely well &, if you intend building it OoB (or just doing a markings/scheme whif), then you should really enjoy building it; but
Secondly (& most importantly): The propeller & shaft fit on a little drum/cylinder-like part which just slips into place without the need for glue, which means that, should you be transporting it to a show or similar, then all you need to do is pull out the cylinder & pack it flat on some foam to avoid having the propeller damaged in transit, then slot it back into place to display it.
That one tiny little detail is a minor stroke of genius! Well done, Airfix! :thumbsup:  :bow:  :wub:  :party:  :cheers:
OK, having a break while my eyes & hands try to recover from trying to paint 1/144" (1/2" RW in 1/72 scale) lines around the cone-shaped pointy bits of bombs freehand. :o
I will state that I flat-out failed, but not as badly as I thought I would. Will need some touch up work & they're not really in scale but they should be good enough. <_<
I still have more lines to paint (1" RW = 1/72" in scale).
The easiest to do is the 4,000lb HC bomb, it's just a big cylinder of thin mild steel around a lot of explosives. Tape works on that! :thumbsup:
What I did when I had to paint a load of bombs was to mask most of the bomb, paint the band forward of that line, then once that was dry paint the bomb colour again leaveing the distance of the band that colour
Hope that makes sense  :-\
It makes sense because I tried 2 variants of that & failed miserably before settling for freehand. :-\
