avatar_NARSES2
My Stash Just Grew Again 2023
Started by NARSES2, December 31, 2022, 05:19:39 AM
Quote from: 2996 Victor on June 01, 2023, 03:54:57 AMI for one will be interested in how you get on with the Quinta 3D-printed cockpit decals. I'm thinking of getting some for my Fw190D-9s that keep turning up inexplicably..... They certainly look very nice but how well do they perform in action? Looking forward to seeing!
Mark
I to will be interested to see how they perform. I've was disappointed with those that were included in the SR 1/A boxing. The Eduard ones I used on the Meteor were better, but still not worth the outlay in my opinion, plus it was only the panel that was 3D, the belts were etch.  For now I'll be sticking with Yahoo etch for cheap and easy panels  :thumbsup:
The Quinta belts are made from the same 'thick decal' stuff, although the instructions are a trifle vague about how they go on. I'm not sure if I'm meant to soak them in water first as they go on to say they have to be glued in place with PVA or Klear.  :-\
2996 Victor
Quote from: PR19_Kit on June 01, 2023, 06:14:10 AMThe Quinta belts are made from the same 'thick decal' stuff, although the instructions are a trifle vague about how they go on. I'm not sure if I'm meant to soak them in water first as they go on to say they have to be glued in place with PVA or Klear.  :-\
Hmmm, that's not very helpful, is it? Oddly enough, I read "something somewhere" recently where the builder mentioned gluing on with PVA and I thought it was a bit strange :unsure:
Mark's workbench:
Spitfire Mk.I Vichy North Africa - Eduard 1/48
Spitfire PR.XIX Rearward-cockpit - Airfix 1/48
Boulton Paul Valiant Mk.I PR - Airfix 1/48
2996 Victor
Quote from: NARSES2 on June 01, 2023, 06:06:30 AMI to will be interested to see how they perform. I've was disappointed with those that were included in the SR 1/A boxing. The Eduard ones I used on the Meteor were better, but still not worth the outlay in my opinion, plus it was only the panel that was 3D, the belts were etch.  For now I'll be sticking with Yahoo etch for cheap and easy panels  :thumbsup:
Mark's workbench:
2996 Victor
Quote from: 2996 Victor on June 01, 2023, 12:06:41 AMI've also scored a Dragon A-5 Special with the Hermann Graf markings from evilBay
Et voila! As if by magic.....
Mark's workbench:
Quote from: 2996 Victor on June 01, 2023, 06:21:16 AM
I think the jury is out on how best to apply them. The ones I've used have been treated as standard transfers, soaked until they were loose on the backing paper, slid onto the part and then coated with Klear.
2996 Victor
@PR19_Kit and @NARSES2 I did a Google search and came up with this "how-to" Quinta 3D Decals review which makes them seem pretty straightforward. I think I'll be ordering a couple of sets from the big H to try out!
Mark
Mark's workbench:
Quote from: Gondor on June 01, 2023, 05:31:37 AM
Quote from: The Wooksta! on June 01, 2023, 04:19:49 AMThere were no C wing lowbacks, other than the Seafire XVII.
Unless you whiff one  :wacko:
There are engineering reasons why this is not possible, otherwise it would have been done.
Quote from: 2996 Victor on June 01, 2023, 06:40:41 AM@PR19_Kit and @NARSES2 I did a Google search and came up with this "how-to" Quinta 3D Decals review which makes them seem pretty straightforward. I think I'll be ordering a couple of sets from the big H to try out!
Mark
Thank you  :thumbsup:
That's interesting. There were no instructions with the ones I've used so far, or very minimal in the case of the Eduard ones. To be honest it's the need to sand down all the raised detail first that puts me off when it comes to the ones I've used. As said the Yahoo panels are simply drop in's, however the Quinta ones do have a lot more useful bits and pieces so I may well give them a try. Although in 1/72 it's not always worth it  :rolleyes:
As an aside I'm not 100% sure all these companies producing 3D "Decals" are using the same materials, but that's based on extremely limited experience of using them.
Hmm, yes. I just read that all through and while it's very informative there were two negative points.
1) He didn't use them as a decal, but dried them off and glued them in place, so we still don't know if you can place them like decals.
2) They're RUSSIAN! :( I may not have bought them had I known that before......
I'll try some of mine as if they're normal decals and see how they stick down.
2996 Victor
Quote from: PR19_Kit on June 01, 2023, 07:34:01 AM1) He didn't use them as a decal, but dried them off and glued them in place, so we still don't know if you can place them like decals.
The way I read it, the answer is no. They're printed on decal paper and there the similarity to waterslide decals ends. That's my interpretation, anyway, FWIW! ;D
Mark's workbench:
I found the instruction sheet that came with mine eventually (hidden between two layers of packing....) and they're the same as the ones he posted in the review. It sort of hints that they MIGHT stick on like decals, but I'm not sure I trust them.
I've scraped the raised detail off the panels etc. and it would have been a lot easier before I'd put it all together of course, but you live and learn.
On other fronts, the 2nd level of PSR has taken place on the starboard wing and it's looking quite good. I think I'll haven to super glue the extensions in place though as they're not too keen on staying connected with only the Contacta glue.
On their way:
2 x DEF Model 1/35 Man 5t. Mil gl Truck Sagged Wheels #2 Continental HCS Tyres for HobbyBoss/Revell (DEF-DW35126) - 1 for my MAN 5t Mil GL truck & 1 for my MAN 7t Mil GL truck
1 x DEF Model 1/35 Man Mil gl Truck Extra Sagged Wheels #2 Continental HCS Tyres for HobbyBoss/Revell (DEF-DW35127) - for my MAN 7t Mil GL truck + the previous
1 x Airfix Models 1/72 Small Starter Set - Willys MB Jeep (AX55117) - to display with 1/72 WW2 aircraft
1 x Tamiya Models 1/48 British Light Utility Car 10HP with Figure (TM 32562) - to display with 1/48 WW2 aircraft
2 x SKP Models 1/35 Assault Rifle vz.58 (4pcs) (SKP-118) - the AK-47 you have when you want something better than an AK-47
1 x Airfix Models 1/32 Vintage Classics Jaguar 420 (AX03401V) - I just like this model of Jag
Received today
From KingKit
1 x 1/72 Hasegawa 00852 Junkers Ju88C-6 'Nachtjagdeschwader'
From the BIG yellow H
1 x 1/72 eduard 70153 Avia CS-199 ProfiPACK, I thought why not when I have many other 199's.
1 x 1/72 AML Accessories AMLA 72 084 Luftwaffe Wgr 42 rocket pods
1 x 1/72 Master AM-72-016 German Radar FuG 220 Lichtenstein SN-2 antenna
1 x 1/72 Quickboost QB 72 561 Messerschmitt Bf 109 Weight Balance
The Wgr 42, could be the Wgr 21 and the SN-2 aerials are for the Ju88 as I have decals by Qwl (OWLDS72011) for an aircraft carrying them, slight problem being the canopy provided in the kit has the singe rear cockpit gun while the decal instructions show two. Reserch is required me thinks.
I can help here, as I've a spare two gun rear for the Hasegawa kit, as the A-4 I have is going to be converted to an S, with a spare nosecone and a single gun canopy from a G that's going to become a 388L-0, but with Jumo 213s rather than BMW801s.
