avatar_NARSES2
My Stash Just Grew Again 2023
Started by NARSES2, December 31, 2022, 05:19:39 AM
I have built/whacked up two of them so far (IIRC), and never had construction issues.  :mellow:
Quote from: Dizzyfugu on July 20, 2023, 11:13:23 PMI have built/whacked up two of them so far (IIRC), and never had construction issues.  :mellow:
Ditto
All four of my PR19 variants came from M'Box Meteor kits. I'm tempted to try one from the Special Hobby 14 though.  ;D
I've built four over the years and never enjoyed it.  The fit is sloppy, loose, and trying to get rid of that join line in the fuselage...
Anyway, eBay says I've won the Revellogawa Heinkel He 111H I was bidding on. Going RW Czech or Spain.  The one below from that oddball met flight unit is top of the list, as most think only of the Spanish Heinkel with Merlin engines, whereas they had Jumos until at least the mid 50s.
Quote from: PR19_Kit on July 21, 2023, 05:36:28 AMMore decals needed?   ;D
Possibly for the He 111J, I think I have the right ones for the H. And the Czech one is available as a sheet anyway.
The J's ended looking similar to the H - I've a photo of one of the J's behind the H above and it's wearing the same codes.  May end up doing three of these as it's just so unusual.
Met flight aircraft are always good for whiffery.   A very convincing backstory can be built  from virtually any aircraft (or balloon ) from about 1860 onwards
The RAF had met flight Mosquitoes and there were proposals for met flight Lincolns and Shattipuss mk.Is
Quote from: The Wooksta! on July 20, 2023, 08:39:04 AM.. The Matchbox Meteor is a vile build, with endless sink holes and fit issues. No trenches, just restrained raised panel lines that just disappear.    The upper deck insert has a join line that is impossible to get rid of.  Definitely needs transverse bulkheads.
And ignore the instructions when it comes to the NF14 nose. The nose for the 12 is correct for the 14.
As usual, a very good run-through - but:
- The tail is perfectly useable for an early postwar single-engined Gloster ground attack project
- the different noses are very well suited as special equipment noses for any Canberra
- the front engine cowlings make very nice tali's/endings cowlings for Hunter based kitbashes with twin tails or butterfly ditto. And come to think about it - one should maybe cut up an old Vampire to see if such an end makes sense there too.
- and finally, the two sets of canopies/canopy frames are also very, very useable for other purposes.
On a side note, while in agreement on the deck insert, I have succeeded rather well with some judicious PSR on this very subject.
Lady luck was on my side again chaps ..just won a auction for a Hobbycraft 1/48th Hawker Sea Fury FB11 Korean War version with these goodies as well
Cutting Edge CEC48346 resin detail cockpit
White Ensign Models PRO4801 resin wheels and metal gear legs
Squadron 9511 Vac form canopy
Lady luck strikes again ..just won a plane ive never had before and it's a WW1 job ..so I get to play with a bi plane again 🤪
I scored a Aurora Gotha GV Kitset in 1/48th ..so another twin 👍
Sweet 😀
Are you going to backdate it to a G.1 configuration?
:wacko: You cannot view this attachment.
Quote from: jcf on July 22, 2023, 07:57:01 PMAre you going to backdate it to a G.1 configuration?
Jon ..mate..buddy ..ol pal ..no!  ;D
This is going to be only the 2nd WW1 plane ive ever built and this model is older than hell 😳
It's from 1972  ..I was 4  :lol:
It could either incredibly frustrating or incredibly interesting..or worse yet..both 😕  ;D
The Chaos
New in my stash over the last months
