Tupolev Tu-13 Kanberra
Started by PR19_Kit, July 29, 2022, 10:31:00 AM
This is a placeholder for my Canberra entry in the LHC Group Build.  ;)
More later................
Here's the kits which will be bashed into the Tu-13, eventually.
Now the Airfix B(I)8 isn't all there, just the wings, and the fuselage that is in the box is from a M'box PR9, and there's also some resin bits, like a rudder and a PR9 bomb bay etc.
And there'll be two U-2s involved in this build......
And yes, the An12, is 1/144 scale.  ;)
Steel Penguin
i was wondering till you got to 2 U-2s  now I'm intrigued
lead on Mr Kit sir,  Lead on!!  :thumbsup:
Neither of the U-2s have any wings of course....................  ;D
Intriguing, are the U-2's going to be pods or booms, and will they be afixed to where the engines of the Canberra would normally be so that the engines from the An-12 with wings are fitted to the outer span of the aircraft?
Gondor the inquisitive
I believe that would extend the wings a bit in the process  :rolleyes:
I may try to write Kanberra in Russian.
But I was wondering: would that use the E Cyrillic very common letter (pronounced "ye", so you should write Kanbyerra or like many people do: OK for writing Kanberra even if that follows imperfectly Russian pronunciation) or the  rare letter э for "ea" (like in weather")?
Канберра   Канбэрра
Quote from: PR19_Kit on July 29, 2022, 11:59:19 AM
Quote from: PR19_Kit on July 29, 2022, 01:07:14 PM
Uh? Do that mean: 2 long U-2 fuselage with 2 tails? This sounds like a twin-boom project so I clap my hands! :thumbsup:
A twin boom Canberra.
The Myasishchev M-17 Stratosphera or M-55 Geophysica springs to mind,(a twin-boom  U-2) although you have overcome the problem of the twin engines with your plan.
Quote from: Tophe on July 29, 2022, 10:44:33 PM
No, it's still got one main fuselage (boom) but it will use both U-2 fuselages as well.  ;D
Quote from: Tophe on July 29, 2022, 06:24:20 PM
Канберра   Канбэрра
Well done Tophe, I was looking at ways of doing that, and I wanted to use the back-to-front 'R' in 'Kanberra' but the only method I could find to write that (Alt+1071) didn't work. :(
Quote from: PR19_Kit on July 30, 2022, 03:06:39 AM
Thanks for what you say that I did not know, yes I am not joking here.
Well, when I type Alt-1071 here I get / (no use of it)
But when I type the same in MS Word I get Я that I can copy there and paste here.
But this sounds as "ya" which is not appropriate for Kamberra, not Kanberrya, or you are right somehow: what-if Kanbyerrya? which is exotic/funny... ;)
Shame.  I was imagining an X wing...
Quote from: zenrat on July 30, 2022, 03:47:08 AM
You're obviously on an X-Wing kick at the moment Fred.  ;D
