avatar_63cpe
What if an 1/48 spitfire was turned into a light bomber
Started by 63cpe, June 06, 2022, 12:17:12 PM
perttime
Shouldn't the engines be mounted lower on the wing? More like the Merlins on a Mosquito.
Wikipedia image
Quote from: perttime on August 07, 2022, 11:36:21 AM
Wikipedia image
I can't disagree with that, it was my first thought on seeing the WiP. :-\
perttime
Quote from: Old Wombat on August 08, 2022, 08:07:20 AM
On the other hand, the spitfire wing is placed lower than the Mosquito wing. Seeing the nacelle so much above the wing might just look strange but be perfectly functional.
63cpe
mmmm, mmmmmm. ok. Is it correct propellor engines are placed in front/ underneath the wings because of wing bending issue's? or is it because of thrustline issue's?
I could put them below the wing allright, but would like to understand why.
thanks,
David aka 63cpe
I think it looks great! Just leave enough room in the nacelle under the wing for main gear and you're in like Flynn.
Quote from: 63cpe on August 08, 2022, 10:49:30 AM
thanks,
David aka 63cpe
It was found to be the best location for reasons related to drag and airflow over the wings, rather than thrustline.
The Westland Whirlwind was low-wing with underslung engines.
63cpe
QuoteIt was found to be the best location for reasons related to drag and airflow over the wings, rather than thrustline.
Ok, but for radial engined propellor this doesn't seem to apply. Radial engines are usually put on the wings at the same level as the cutting edge of the wing (stirling, Wellington, Beaufighter, B-17, B-24). Why shouldn't this apply for radials?
Only the Vickers Wellington MKII had the Merlins above the wing as a result of the nacelle designed for radials. Although there were some initial stability and balance issues these were all sorted with enlargement of the tailplanes.
Any body any thoughts about Inlines above the wings?
David aka 63cpe
Flyer
The twin P-40 concept had it's inline engines above the wing, and almost every modern civil twin I can think of with a low wing has the engines mounted above...
Just go with what you think looks "right" :thumbsup:
BTW I like the look of your Spitfire with the motors over the wing.  ;) :thumbsup:
tahsin
Ed S
This was my take on the subject from few years ago.  Shown here next to a 1/72 Spitfire.  I did use Griffons since I didn't have any 1/72 Merlins available.  I made molds and vacuformed new canopies and nose.
Engines (or more importantly props) mounted above the plane of the wing would result in more air being blown across the upper surface of the wing generating more lift resulting in shorter take off run and greater load carrying capacity.
Just to further muddy the waters, the Supermarine Type 327 had them mounted on the midline:
