avatar_Tophe
Boeing-X Sensor-Y (finished part 2 page 5+5, part1 page3)
Started by Tophe, January 13, 2022, 07:12:44 AM
Gluing resin to plastic is not easy. I used cheap cyanoacrylide glue bought by my wife, but it was almost not working, I added a part of sprue as support to make it more solid (this will not be seen on the final model), I will see after several hours if this is actually glued. :unsure: :-\
= link http://www.kristofmeunier.fr/IMG_5351_sens.jpg
Looking weird as usual Tophe  :thumbsup:
This is going to be one very different Mustang thats for sure  ;D
When you apply the cyanoacrylate glue sprinkle baking soda on it and it will set up immediately. If you do this in layers it can be built up as a filler.
Looking forward to seeing your results on this fun build!
Thanks a lot for the advice while I cannot walk anymore and go to the kitchen upstairs, I will probably try again without baking soda. Thanks anyway. :thumbsup:
Quote from: Wardukw-NZ on January 26, 2022, 01:37:00 AM
Uh? :unsure:
All the P-51S-5 (1,000 copies scale 1) are just like that, isn't it normal for a Mustang? ;D
= link http://www.kristofmeunier.fr/IMG_5352_sens.jpg
(or maybe this is just in my dreams...) ;)
I have added putty to improve solidity (wing) and shape (belly): <_<
= link http://www.kristofmeunier.fr/IMG_5358_sens.jpg
Sanding is done, then I painted the resin and plastic in the same light blue color: <_<
= link http://www.kristofmeunier.fr/IMG_5365_sens.jpg
This is not finshed but the aspect is well advanced.
Then painting the side below (not to be seen in routine):  :unsure:
= link http://www.kristofmeunier.fr/IMG_5374_sens.jpg
Surprisingly, I have added wheels on this model, instead of sending them to garbage (or spare parts box) as I do usually: :unsure:
= link http://www.kristofmeunier.fr/IMG_5380_sens.jpg
What are these two wheels for?
–   If I were a realist plane-lover: this would be to roll and take-off then land back home, and this would require a third wheel, but no I am not this one.
–   If I were a realist modeler: this would be to stand on the shelf, without in flight display pylon, and this would require a third wheel, but no I am not this one.
–   As a crazy whif modeler (and lacking skills & PSR courage), this is to hide the imperfect putty/sanding I made on the belly, and yes I am this one... :-\ ;)
The North Boeing P-51S-5 Sensor Mustang model is finished! <_<
= link http://www.kristofmeunier.fr/IMG_5384_sens.jpg
+ http://www.kristofmeunier.fr/IMG_5386_sens_x4.jpg
Then remains to be built the other plane with remaining parts.
Scotaidh
I like it!  When you posted the picture of the aircraft upside down, the absence of the wing made the radiator look really, really big with a very large "mouth"!  I liked that a lot - it seemed to indicate a very powerful engine.
But what you have is very different, and I find it pleasing to the eye.  :)
Well done, my friend!  :)   :thumbsup: :thumbsup:
