avatar_Dizzyfugu
DONE +++ 1:72 Messerschmitt Me 262 F-2b, "Gelbe 4" of III./JG 53; Kassel, 1946
Started by Dizzyfugu, November 01, 2021, 03:48:27 AM
What would a "Gunships" GB be without some sick, gun-toting Luft '46 creation? So, my first project will be a Messerschmitt P.1099 (Revell kit) with a heave 55 mm gun in the nose. Quite straightforward, but I have everything at hand for this one.  :mellow:
However, there are currently two other models waiting for photo sessions, so that it might take some days until this Kanonenvogel takes off.
Those Revell Luft 46 kits are quite pleasant builds. Looking forward to this  :thumbsup:
hardware work has started, and it truly is a nice kit. Fir is very good, no fights so far, even though I find some detail irritating (like the tractor profile on the main wheels, WTF?) and there are "mistakes", too, like the engine nacelles which should be placed further back under the P.1099's wings. So, there's still room for mods and improvements, beyond a big gun in the nose.  ;)
I'd give it a different RLM number as it's  a largely different aircraft.  IIRC, back when I was doing Napkinwaffe, I gave it the Me 327 designation, as it was in a block of numbers allocated to Messerschmitt.
Somewhere I have a Czechmaster one that never got finished and that had similar shape issues.  They also did the P.1100 Schnellbomber in two variants, one that looked similar to the P.1099 but with a Canberra style offset canopy and one with wing root mounted engines reminiscent of a sawn off Buccaneer.
Progress is good; engine nacellles have been modified (moved back, as they should be), wings are in place, stabilizers have been replaced with slightly bigger alternatives and a fairing for the gun has appeared.
Not much progress here recently, got struck again by an allergic shock. However, assembly and modification has been finished so far, and painting is about to start. However, after the Taiwanese Kfir there's still another completed model in the pipeline waiting for pics...
Hope your ok Dizzy and fully recover quickly  :thumbsup:
Thank you, I am walking upright again after three days in K.O. condition.  :rolleyes:
You get used to it, but it's no real fun... Esp. when it was apprently not triggered by something wrong I had eaten, but probably rather through hydrochlorite fumes from a toilet cleansing agent.  :-\
In the meantime, paint has been added to the model - and this turns out to become a fight. I used Humbrol RLM tones, and while the enamel paints were opaque and looked/felt reassuring, they won't dry properly and remain sticky. China crap, I guess. I try 48 hrs. on the radiator, I hope the extra warmth improves the situation before further steps can be made.
A night under "soft baking" conditions helped - the enamels dried, but the finish is glossy and the apint itself still somewhat soft, I hope the poor paint did not ruin the project. Carefully plodding on.
Project more or less finished, turned out bettr than expected after the paint mess. Now in queue for pictures...  :rolleyes:
Well, after some (long  :rolleyes:) waiting, I was finally able to take pictures of the model and edit them - quite a lot. But here we go with the first GB entry:
1:72 Messerschmitt Me 262 F-2b (P.1099) "Pulkzerstörer", early production; "Gelbe 4" of III./JG 53  "Pik As" (Ace of Spades), Deutsche Luftwaffe; Kassel, April 1946 (What-if/modified Revell kit)
by Dizzyfugu, on Flickr
Some background:
The Messerschmitt Me 262 F was a series of multi-purpose jet planes designed by Messerschmitt for the Luftwaffe that entered service during the final phase of the Second World War in Europe. The aircraft's design was begun in the summer of 1943 under the project handle P.1099, intended as an improvement to the successful Messerschmitt Me 262 jet fighter and also as a replacement for the Arado Ar 234 bomber/reconnaissance aircraft. The primary focus was on more payload, being either usable for more fuel (since early jet engines had poor mileage and therefore range and endurance) or for weapons, including bombs in an internal bomb bay that would enable the aircraft to fulfil a similar tactical role as the British de Havilland Mosquito. Beyond this high-speed bomber (Schnellbomber) variant, the P.1099 would also be a suitable basis for a fast reconnaissance plane, interceptors and night fighters, and trainer versions were also planned.
The Messerschmitt P.1099 was a 12 m long, conventional-looking aircraft with a wingspan of 12.6 m. It had a much wider fuselage than the Messerschmitt Me 262. It had a circular shape with a diameter of 1.7m (5 ft 6¾ in) and the cockpit was now moved closer to the aircraft's nose, above the front landing gear well. The baseline aircraft featured a side-by-side cockpit for a crew of two, even though different layouts were envisioned for the specialized variants, including single-seaters. To save development time and to use existing jigs and tools as much as possible, the P.1099 retained the wings and the tail section of the Me 262A-2a. Despite a higher total weight (the P.1099' MTOW was about 3 tons higher), the planned powerplants were initially two uprated Junkers Jumo 004 turbojet engines, later to be replaced by more powerful Heinkel HeS 011 turbojets.
In January 1944 the P.1099 was accepted by the RLM and received, despite the aircraft's different structure, the designation "Me 262 F". The first variant, the Me 262 F-1 (internally designated P.1099A), was the baseline aircraft under the handle "Jäger I", a jet-powered single seat daytime fighter. There were three planned versions, differing mainly in armament: Version F-1a was armed with four MK 108 30 mm cannon in the lower fuselage, comparable with the earlier Me 262 A fighter, just with more fuel and ammunition. Version F-1b carried two MK 103 30 mm cannon with longer range, firepower and ammunition supply, and Version F-1c was a heavy daytime fighter with two MK 108 and two MK 103 cannon in the nose.
In parallel the Me 262 F-2 was developed as a more heavily armed and armored variant, as a dedicated heavy bomber interceptor ("Pulkjäger" or "Zerstörer") under the handle "Jäger II". Again, three versions were foreseen: Version F-2a would be armed with a single MK 108 cannon and a heavy MK 112 55 mm cannon in the nose. Version F-2b was the same, but it was armed with a MK 114 50 mm cannon instead of the Mk 112. Both were single seaters with a heavily armored cockpit and canopy.
The F-2c was a more thoroughly modified two-seater version; it was armed with a single MG151/20 in a small nose turret, a pair of Mk 103 in the rear of the cockpit firing up- and backwards and two defensive MG 131 in remote-controlled FDL 151 barbettes in the tail. Due to the significant changes this model had the internal project designation P.1099B.
Another two-seater, the F-2d, remained very close to the original baseline aircraft with a crew of two in a side-by-side cockpit. This aircraft was armed with the standard four MK 108 in the nose, plus one launch rail under each wing for Ruhrstahl X-4 guided missiles, which were launched and steered by the second crewman via a wire connection with the mothership. This variant did not come to fruition, however, after the X-4 missile project had been cancelled in early 1945.
All P.1099 fighters also had hardpoints under the outer wings for racks with twelve 55mm R4M unguided air-to-air missiles each, a detail taken over from the Me 262 A, even though the fuel load had to be reduced to carry them. The radio equipment of all these versions would be a FuG 16, Peil G6, FuG 101 radio altimeter, FuBl 2 blind landing equipment, as well as the FuG 25a Erstling identification friend or foe transceiver.
Beyond these initial day fighter variants, further types based on the P.1099 airframe were envisioned, too. The F-3 was a dedicated night fighter version, developed in parallel to the Me 262 G. It was based on the F-2a heavy day fighter, but it carried a crew of two (the pilot and a rearward-facing radar operator) and was equipped with a FuG 240 "Berlin" radar set and a rotating dish antenna under a streamlined plywood cover in the nose. The armament consisted of four MK 108 under the nose, similar to the F-1a day fighter, plus two additional, upward-firing MK 108 cannon ("Schräge Musik") in the rear fuselage.
Other proposed variants (with less priority, though) were the F-4 and the F-5, which were to become the basis for fast bombers and reconnaissance aircraft with only light defensive armament, typically only a pair of MG 131 in remote-controlled tail barbettes was to be carried. The F-4 resembled the baseline P.1099A, with two bomb bays in front of and behind the main landing gear wells and a crew of two seated side-by-side in a pressurized cockpit. Two MK 108 were carried in the nose, plus the MG 131 tail barbettes. The F-5 was similar but featured a glazed bomb aimer/navigator station in the nose instead of the MK 108's and the glazing above the pilot's station was reduced and asymmetrical. In both bomber variants the fuselage tanks were re-arranged to make room for a single SC 1.200 in the front bomb bay, but combinations of smaller bombs could be carried, too. Alternatively, mounts for up to three cameras or a 1.350 l auxiliary tank for extended range could be carried in the bays, too.
Initial flight tests of the Me 262 F in late 1944 showed severe directional instability: especially after fuel and ammunition had been depleted and the center of gravity shifted the aircraft tended to become nose-heavy and ditch down if it was not carefully monitored and trimmed by the pilot. To cope with this problem, the engine mounts were modified, so that the CoG was shifted back. Compared with the original Me 262 the engines were placed roughly 900 mm (35.5 in) further back under the wings. The emptying sequence of the fuselage tanks was also changed, and this mostly mended the problems. Another measure to mend the directional instability issues was the enlargement of the tail surfaces, even though later production aircraft frequently had smaller Me 262 A stabilizers fitted due to material shortages and simple lack of parts.- However, due to the higher weight the Me 262 F's handling and agility were very limited – but most of its intended roles rather relied on speed, anyway, so that dogfights could be avoided.
From 1944 on the war situation worsened considerably, and production of the new Me 262 F superseded the A variant only on selected production lines. A disused mine complex under the Walpersberg mountain was adapted for the production of complete aircraft. These were hauled to the flat top of the hill where a runway had been cleared and flown out. Between 20 and 30 Me 262 Fs were built here until early 1946, primarily fighters, the underground factory being overrun by Allied troops before it could reach a meaningful output. Wings were produced in Germany's oldest motorway tunnel at Engelberg, to the west of Stuttgart. At B8 Bergkristall-Esche II, a vast network of tunnels was excavated beneath St. Georgen/Gusen, Austria, where fully equipped fuselages for the Me 262 at a planned monthly rate of 450 units on large assembly lines were to be produced from early 1945.
After the type's introduction to frontline units in early 1945 further handling problems arose through the aircraft' weight, resulting from its high wing load. Both starting and landing run were excessive, so that the number of airfields from which it could be operated was relatively small. No real short-term solution could be found without fully re-designing the wings, so that RATO bottles were frequently used to get a fully loaded Me 262 F up into the air from standard airfields. These were typically fitted to racks which were mounted under the fuselage, flanking the rear bomb bay.
The Me 262 F's landing speed was dangerously high, too. A retrofittable brake parachute, housed in a simple tubular fairing under the tail, was developed to reduce the landing distance and save brakes, which frequently overheated and could set the landed aircraft aflame.
From the Me 262 F-2a "Pulkzerstörer I", only a small number were built and eventually entered service. Its main armament, the MK 112, was a heavy German machine cannon produced by Rheinmetall-Borsig from 1945 on – in fact, the MK 112 was basically a scaled-up MK 108, a very compact weapon with relatively low weight. The MK 112 had a caliber of 55 mm and thus fired much larger shells than the 30 mm MK 108, but the rate of fire was significantly lower (300 rounds / min compared to about 600-660 rounds / min of the MK 108). This large-caliber gun was designed primarily to combat heavy bombers, its rate of fire would have been too slow for effective aerial battles with escort fighters – but the Me 262 F would not have been a dogfighter, anyway, so that the "hit-and-run" mission profile suited the aircraft well. Fire tests showed that a single MK 112 hit with mine grenades could destroy a bomber, and with a rate of fire of five shells per second this weapon could inflict considerably higher losses on the incoming streams of Allied bombers compared to other on-board weapons used on the German side. Only the unguided R4M missiles were as effective, but the MK 112 offered considerably higher accuracy and the opportunity to execute more than just a single attack run on an incoming bomber formation.
The MK 112 was mounted in the lower starboard section of the Me 262 F-2a's nose, its barrel protruded more than 2 m (7 ft) from its nose. The gun's drum magazine with sixty rounds partly took up the rear space of the cockpit behind the pilot and the gun mount even used up space of the weapon bay on port side, so that only a single MK 108 with 100 rounds as an additional weapon was mounted in the lower port side weapon bay.
Its sister, the Me 262 F-2b, remained on the drawing board, because its main weapon, the 50 mm MK 114 autocannon that had been derived from the 5 cm Pak 38 anti-tank gun, had turned out to be over-complicated, overweight and unreliable. A refined version was developed as the MK 214A, though, but after flight test from February 1945, but the weapon was not deployed operationally.
Only a handful Me 262 F-2a Pulkzerstörer were eventually fielded and operated before the end of hostilities – beyond the low production numbers the lack of fuel and loss of suitable airfields highly limited the aircraft's potential. Probably less than ten were used by operational units, including JG 53 "Pik As", in which they served alongside other interceptors, including other Me 262 variants. Typically, bomber formations were approached from the side of a bomber formation, where their silhouettes were widest, and while still out of range of the bombers' machine guns. This broadside-attack tactic was very effective, and the aircraft's high speed allowed the interceptors to turn around 180° and make at least a second attack run from the opposite side, before the machines dashed off and returned to their bases.
General characteristics:
    Crew: One
    Length: 14,32 m (46 ft 11 in) overall
            12,00 m (39 ft 3¾ in) fuselage only, w/o brake parachute housing
    Wingspan: 12,61 m (41 ft 3¾ in)
    Height: 4,43 m (14 ft 6 in)
    Wing area: 24,2 m² (236 sq ft)
    Empty weight: 5.061 kg (11,148 lb)
    Loaded weight: 8.762 kg (19,300 lb)
    Max. take-off weight: 10.062 kg (22,163 lb)
Powerplant:
    2× Junkers Jumo 004 C turbojets with 12 kN (2,697 lb st) each
Performance:
    Maximum speed: 930 km/h (577 mph, 505 kn)
    Cruising speed: 805 km/h (500 mph, 438 kn) at 6.500 m (21,290 ft)
    Range: 1.340 km (830 ml, 728 nm) at 6000 m with internal fuel only
    Service ceiling: 11,450 m (37,570 ft)
    Rate of climb: 18 m/s (3,540 ft/min) at max. weight
Armament:
    1× 55 mm (1.96 in) MK 112 machine cannon with 60 rounds
    1× 30 mm (1.18 in) MK 108 machine cannon with 100 rounds
    Hardpoints under the outer wings for racks with twelve 55mm R4M unguided air-to-air missiles
The kit and its assembly:
This what-if model was based on Revell's interpretation of the P.1099A, and the kit goes together well. Fit is very good, even though some designs are IMHO a bit dubious. The kit's weakest point: Revell unfortunately missed the important detail of the modified engine nacelles: the kit comes with standard Me 262 wings and engines, but due to CoG reasons the P.1099 would have had its engines moved back by about 900 mm, as mentioned in the background. I corrected this on this build with some PSR – sounds simple, but since the nacelles are not expected to be stuck to the wings in their new position roughly 1 cm further back, some serious bodywork had to be done.
Otherwise the kit was basically built OOB. I just left away the inner wheels from the main landing gear because I found the twin wheels to be "too much" for this upgraded Me 262. The P.1099 might have been heavier than the Me 262, but...? And the wheels' tractor-like tread design looks IMHO out of place, too, so that I replaced them with a pair of MiG-21 wheels, left over from a KP kit.
1:72 Messerschmitt Me 262 F-2b (P.1099) "Pulkzerstörer", early production; "Gelbe 4" of III./JG 53  "Pik As" (Ace of Spades), Deutsche Luftwaffe; Kassel, April 1946 (What-if/modified Revell kit) - WiP
The cockpit was taken OOB, even though I have doubts concerning the canopy. And when you look at mockup pictures of the P.1099 you realize that cockpit access had been facilitated through a side door at starboard, similar to the D. H. Mosquito. The cockpit tub does not consider this hatch at all, and the engraved door on the fuselage (it's actually there!) is so tiny that only a Halfling might use it?
Well, I stuck with it "as is" and just added a pilot figure (specifically from a Matchbox Hawker tempest, because it is one of the rare cases that you get a WWII pilot wearing an oxygen mask) and a "barrel" behind the bulbous pilot seat because there's a lot of free space in this single seat variant that is otherwise occupied by a rear gunner in Revell's P.1099B kit. I also have doubts concerning the kit's canopy, since the original P.1099 had a cockpit for two seated side-by-side, with a canopy that resembled the D.H. Mosquito's a lot. I am also not certain about the stabilizers – the kit comes with standard Me 262 parts, but trustworthy sources I consulted suggest that not only the fin had been enlarged (depicted well in Revell's kit), but also the stabilizers? To improve this, I implanted a pair of modified stabilizers that came from a Heller PZL P.23 light bomber. Sounds odd, but they were a very good match in size, shape and thickness!
The only major modification concerns the armament, even though it became just a "graft-on" solution. On the lower left side, the upper gun port was PSRed away. On the right side I added a bulged fairing for the MK 112. It was sculpted from a Matchbox Saab J29 drop tank and blended into the hull with PSR. Protruding spent cases fairings were added for both guns. The MK 112 gun barrel is a resin piece, left over from a ModelTrans tank conversion set and actually depicts a German 55 mm gun, so that this became a perfect donor piece.
Since the airframe still looked rather clean and boring I finally added a pair of JATO bottle racks to the rear fuselage (scratched from styrene profile but left empty) and a brake parachute fairing under the fin, carved from a piece of sprue.
Furthermore, a display adapter was installed into the fuselage for in-flight pictures.
Painting and markings:
This became a challenge, because I wanted a rather unusual livery, neither a standard RLM 81/82/76 late-war combo nor an improvised-cammo-over-bare-metal finish. After some research I settled upon something that was actually carried by some He 177 bombers around 1944: a uniform RLM 74 (Graugrün, Humbrol 245) upper surface with "cloudy" mottles in RLM 76 (Humbrol 247). This appears like a winter camouflage, but it's actually quite effective at medium altitude, esp. over a cloudy landscape. The original bombers had light blue (RLM 65) undersides, but for the P.1099 from a later period and as a fighter I rather used a darker shade of RLM76 in the form of Tamiya XF-23 (Light Blue). The model received a black ink washing and some post-panel-shading.
The cockpit interior became RLM 66 (Schwarzgrau, Humbrol 67) while the landing gear and the well were painted in uniform RLM 02 (I used Revell 45, a slightly more greenish tone), with wheel discs in RLM 66, too.
Unit markings became minimal and quite sober. I gave the aircraft a typical late-war "Reichsverteidigung" fuselage band, and in JG 53's case it is plain black. The black band was deliberately chosen because it is a good, much darker contrast to the murky RLM 74, so that the latter appears lighter than it actually is, lowering the contrast to the RLM 76 spots.
The decals were puzzled together from various sources. As an aircraft of the 3rd group the unit's ID color would be yellow, reflected in the tactical code and the fin tip. For some contrast and to emphasize the long gun barrel I gave it white and black stripes – as a security measure for ground handling. For some more variety I painted one air intake in very dark grey (Revell 06, Anthracite) and the other one in steel Metallizer, simulating replacement parts. The Balkenkreuze come from various sheets – I used simplified  "low viz" versions all around. The undulating yellow bar for the 3rd group comes from a TL Modellbau sheet, while the yellow "4" came from a Fw 190 A sheet from Sky Models. A small "4" on the nose was added as a wacky detail, too, the "Pik As" unit markings came IIRC from a Hobby Boss Bf 109 sheet. Since they turned out to have poor contrast/opacity I only used a few stencils from the P.1099A sheet, but due to the disruptive paint scheme this is not apparent.
Finally, the model was sealed with a coat of matt acrylic varnish (Italeri) and a wire antenna, scratched from heated black sprue material, was added between cockpit and fin.
Well, this modified Messerschmitt P.1099A looks simple, but the modified engine nacelles as well as the gun fairing under the nose called for serious PSR. The result looks quite natural, though, and AFAIK this weapon configuration was actually on German drawing boards. However, I am not certain about the cockpit canopy and other details on Revell's kit, reference information is contradictive.
The paint scheme looks good, even though it was lent from a heavy bomber, and the poor Humbrol enamels did not yield a finish that I had hoped for – the paintwork could certainly have been better, but the overall impression of a late-war Pulkzerstörer is O.K., and this eventually counts.
Hmmm, Google Translate decided that Pulkzerstörer was Swedish (English Pulkzerstör :unsure:), when told to translate from German, it came up with Bulk Destroyer as the English equivalent.
Pretty sure that's not the "contextual" translation.
Ugly critter, ain't it! :o Nice bit of whiffery, though! :thumbsup:
I think you have the engine front's and rears on the wrong ends Dizzy. The fronts are the more rounded parts where the rear is a much more defined taper. Nice result though  :thumbsup:
