avatar_Lost Cosmonauts
Lost Cosmonauts' 3D printed what-if playthings and emporium
Started by Lost Cosmonauts, August 11, 2021, 07:12:21 AM
Lost Cosmonauts
Quote from: PR19_Kit on February 12, 2022, 11:38:12 AM
That's your Miles M52, isn't it?
Looks lovely.  :thumbsup:
Oops! Yeah, I forgot that small but salient point.
Miles M.52 at 1/72 scale culled from my meagre stock
Quote from: Lost Cosmonauts on February 12, 2022, 12:00:56 PM
A meagre stock is all you need when you can make to order.
Leading Observer
My FD3 and Z.221 [short Blue Steel] arrived today :thumbsup: I'm thinking the short Blue Steel will be fitted to a Mirage IV :-\
LO
Lost Cosmonauts
Quote from: Leading Observer on February 12, 2022, 02:37:43 PM
Excellent, glad they got there ok & hope you enjoy both
Quote from: Gondor on February 12, 2022, 02:09:35 PM
That's the plan, minimal stock and just run off whatever last sold. Hasn't quite run smoothly yet as I had a face and then printer malfunction but hopefully I'll find a solid groove where I can support the existing stuff and add a couple of new things every month
Lost Cosmonauts
#184
Horrible weather last week meant a bit more time on the digital bench
A first stab at the Armstrong Whitworth AW.171 has been made
Lost Cosmonauts
#185
More progress on the AW.171 - most of the major bits are there. Bit of finessing needed then organising the print parts
"Where's the fuel gauge?" "Fuel gauge!? This thing has two massive propulsion engines, ten lift engines and precious little internal volume. No need for a fuel gauge, just turn an egg timer over when you start the engines and make sure you've landed before it runs out. Soft boiled  mind you to allow for a safety margin."
Lost Cosmonauts
Still pottering away on the Miles M.52 - doing a little bit here and there while prints are either cleaning or curing so it tends to just be 5 minutes at a time. All just about there and we're into filling and sanding
Lost Cosmonauts
I have tools, paint and glue again! Hallelujah and all that
M.52 got assembled
https://flic.kr/p/2nrtrHW
Was in good enough shape for a test flight
https://flic.kr/p/2nmBjZi
It even got some decals flung haphazardly at it
https://flic.kr/p/2ntszyr
https://flic.kr/p/2ntrm56
In the rosy afterglow of actual model making I started two more (Avro 698 and Vickers Swallow) at 1/144
https://flic.kr/p/2ntykb1
Which are both now in first coats of primer
https://flic.kr/p/2nuootA
https://flic.kr/p/2nuuVhE
Lost Cosmonauts
Quote from: PR19_Kit on June 26, 2022, 12:28:47 PM
LOVE that M52, specially the Schlieren pic.  :thumbsup:
Thanks, I was idly dabbling with image editing and did another
https://flic.kr/p/2nmKbM3
Lost Cosmonauts
I was pottering around tidying and shutting up the workshop (taking a month off) and in an idle moment rather than throw away a first draft (flying surfaces too thin so I thickened them up for draft 2) 1/72 Z.122 nuclear ramjet version of Blue Steel I superglued it together and threw some primer at it
https://flic.kr/p/2nvKcYd
Is that the one on facebook?  Orac doesn't like flickr.
Lost Cosmonauts
Quote from: The Wooksta! on July 02, 2022, 01:57:16 PM
Yes, same one. Did you get one already?
Yes, you sent me a test print a while back.  Very nice too, I was very impressed with it.  Not done much but gave it a good sanding.  I'd have to dig out the Vulcan parent/launch ship first anyway afore I do much more with it.
