The Nakajima Ki-87
Started by rickshaw, April 05, 2021, 01:05:42 AM
The Nakajima Ki-87
The Heinkel He 119 was an experimental single-propeller monoplane with two coupled engines, developed in Germany. A private venture by Heinkel to test radical ideas by the Günter brothers, the He 119 was originally intended to act as an unarmed reconnaissance bomber capable of eluding all fighters due to its high performance.
Developed to utilise the combine engine of the Daimler-Benz DB601 engines mounted above the wing centre-section within the fuselage, mounted together within a common mount (the starboard component engine having a "mirror-image" centrifugal supercharger) with a common gear reduction unit fitted to the front ends of each component engine, forming a drive unit known as the DB606, the first German aircraft to use the "high-power" powerplant system. meant to provide German aircraft with an aviation powerplant design of over-1,500 kW (2,000 PS) output capability, but weighing 1.5 tonnes apiece.
The aircraft featured a revolutionary evaporative cooling system as well, with radiators under the skin of the wing, cooled by the normal airflow.  However, this really wasn't sufficient as was found with the V1 prototype, so a retractable radiator of conventional form was added under the fuselage.
Heinkel developed the aircraft but the Reichs Luftministen had no interest in.  Heinkel developed several record breaking versions of the aircraft both as land and float plane based versions.  However, they failed to achieve their records.
Japan however was interested in acquiring new technology and purchased two versions of the He119, the V7 and the V8 in    1940.   The Imperial Japanese Army gave them to the Nakajima combine with instructions to study them and develop their own versions.  Nakajima already had licence rights to produce the DB601 engine so the DB606 was quite within their reach.  What the Imperial Japanese Army didn't like that much was the evaporative cooling system but accepted that was what made the He119 a world beater when combined with it's power plant.  They also didn't like that the aircraft was unarmed and insisted a tail turret be incorporated in it's design.   The result was the Nakajima Ki-87, a medium sized reconnaissance bomber able to match the performance of the Imperial Japanese Navy's Mitsubishi Ki-46.
Problems became however apparent when the aircraft was introduced into limited service in late 1941.  In theory it could fly higher, faster than most Allied fighters at that point in the war.  The engines however were unreliable and rarely managed to produce their rated power.  The turret was so cramped that only the smallest airman could be accommodated.  The evaporative cooling system actually proved relatively simple and troublefree.   The aircraft only saw limited service as a consequence and failed to achieve any successes against the enemy.
The Kit
The kit is the Valom He119.  The turret is actually intended for the He177a5.  The paint is by Vallejo and rattlecan.  The markings are from the sparesbox.
Nice!  :lol:
I am just not certain about the Ki-87 designation: I have immediately the R/W interceptor prototype on my radar...  :rolleyes:
Ki-87 is of course spurious.   :thumbsup:
VERY ingenious Brian, I like that a lot!  :thumbsup:
I've got a floatplane 119 kit in The Loft too, that's given me some ideas about it............  ;)
Quote from: chrisonord on April 05, 2021, 04:04:18 AM
Marvellous  :thumbsup:
It is indeed  :thumbsup:
I didn't know Valom did one Brian. What did it build like ?
Quote from: NARSES2 on April 05, 2021, 06:02:46 AM
Pretty good.  Had a bit of a problem with the wings.  No locating pins.  The turret was a bit of a challenge but overall it was an OK kit.
Wurgerman
Super cool whif, Japan's answer to the Defiant ! 👌
Wurgerman
