avatar_TomZ
Handley Page HP-42 in 1/72
Started by TomZ, October 26, 2020, 12:25:21 AM
TomZ
He also has a website: http://one-man-model.main.jp/
You can download the instruction sheets there for all his models.
TomZ
That is indeed a very fine print from filament type 3D device as the rafts appear to indicate it is.
royabulgaf
How are the corrugations?  Could you furnish a close up of the fuselage?
TomZ
Quote from: royabulgaf on October 27, 2020, 09:35:20 AM
Here are some close ups:
TomZ
Quote from: loupgarou on October 26, 2020, 06:36:30 AM
Quote from: zenrat on October 26, 2020, 03:30:00 AM
Interesting.
Can you glue the parts with normal model glue?
In some other ebay ads, the seller specifies it's ABS, so normal plastic glue won't give a strong enough bond. I hope Tom has some specific glue for it.
Railway modelers know all about ABS, Plastistrut is made of it. I've got a bottle of liquid glue that works on it too as I use quite a bit of their neat stuff.
Interesting.
'Hot' cements for HIPS (High Impact Polystyrene) also work on ABS (Acrylonitrile Butadiene Styrene).
royabulgaf
The corrugations look better than I thought.  I saw some photos on another site and they looked like corduroy cloth.
You spoil us Tom, using a 20.p coin  ;)
TomZ
Quote from: NARSES2 on October 29, 2020, 07:18:33 AM
If you send me a 100 pound note I will do one with that  ;D ;D ;D ;D
TomZ
TomZ
Just before closing up the fuselage:
TomZ
Scotaidh
Wow!
Although I am wondering how visible the dunnies will be when it's all closed up.
But still.  Wow!
TomZ
Quote from: zenrat on November 11, 2020, 02:25:46 AM
Yes, there is a very small round window for each, about 3mm diameter. So you probably won't see anything.
But as the super detailers (which I am definitely NOT) will tell you: I know it's there.....
TomZ
