avatar_Gondor
The REAL Wessex HC.2 Protatype
Started by Gondor, July 11, 2020, 02:29:24 PM
The ejector pin marks on the inside of the fuselage halves have been filled and are now sanded back using a mini drill and sanding bit. This removed some of the internal frames, but I have to add some anyway to go over the inside of the filled-in window.
My solution, grind off a bit more of the frame and replace it.
Here are the first two lengths fitted. Only spot glued in place at the moment, once I am happy with them, I will run a bead of glue along the whole length. The material is some wire from an old USB cable. It's just the right size, which is smaller than the Evergreen strip that I have.
