Author Topic: DONE @p.2 +++ 1:72 G.91X, Fuerza Aérea Hondureña, 1988  (Read 1056 times)
Offline Dizzyfugu
« on: June 13, 2020, 12:43:21 am »
Since the first ideas are revealed I will chime in and sketch out my plan for this year's 1WGB. As mentioned in the general discussion thread, this will be a modified Yankee Gina, based on the Matchbox kit. The G.91Y was built on behalf of the Italian Air Force, but what if Fiat also developed a downgraded, simpler export version with just a single but bigger engine for countries with rather small budgets? Enter the G.91X!  :lol:
And there's also already an exotic operator for it: Honduras, with some supply synergies with the country's ex-Israeli Sa'ar/Super Mystère fleet.  ;)
We'll see if that's workable in just a week, including some self-printed decals, background story and beauty pics to present the model.
« Last Edit: June 19, 2020, 11:34:52 am by Dizzyfugu »
Online Tophe
    • my what-if models
Re: 1:72 G.91X, Fuerza Aérea Hondureña, 1988
« Reply #1 on: June 13, 2020, 12:47:14 am »
Good project! :thumbsup:
It will be OK if you simply make "pictures" at the end, "beauty pictures" are better but not obligatory! ;)
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #2 on: June 13, 2020, 12:56:58 am »
'Just a week'?
I didn't think such a long time scale existed in your world Thomas.  ;D ;)
Offline Dizzyfugu
Re: WiP +++ 1:72 G.91X, Fuerza Aérea Hondureña, 1988
« Reply #3 on: June 14, 2020, 12:35:59 am »
Things took off yesterday, actually with some home-made decals since the flag for the fin and optional roundels are unobtainable.
1:72 Aeritalia G.91X; Fuerza Aérea Hondureña (Honduran Air Force, FAH), 1988 (Whif/modified Matchbox kit) - WiP
by dizzyfugu, on Flickr
On the hardware, the saw started screaming. Here's a look at the Yankee kit, together with a "normal" R Gina that will provide its bottoms:
Besides the obvious differences in length, the rear fuselage shapes are totally different, so that the transplantatation won't be as easy as it seems...
In order to mount the donor panels I added some internal holders:
The outcome does not look too bad, even though some heavy PSR will be necessary (not obvious in this shot):
In parallel, the cockpit got a little pimped, since the OOB piece is, beyond a separate dashboard, a very basic affair. The pilot comes from the donor bank, too (left over from the Thai A-4).
After adding putty to the fuselage, yesterday's last measure was the addition of the cockpit tub and the landing gear wells to the fuselage halves, as well as some lead.
1:72 Aeritalia G.91X; Fuerza Aérea Hondureña (Honduran Air Force, FAH), 1988 (Whif/modified Matchbox kit) - WiP by dizzyfugu, on Flickr
Sanding next, and the wings will be modified (flaps down). Hope I can close the fuselage today.
Offline Dizzyfugu
« Reply #4 on: June 14, 2020, 07:53:33 am »
Day 2, things keep moving forward. Fuselage halves were closed this morning, and the expected 2-3mm gap between the R-Gina tail pieces becomes visible. But that's nothing a styrene strip and some PSR could not mend...
What will become tricky is the exhaust opening. It's somewhat oval in shape and has to be re-sculpted, and I have to find a donor jetpipe that fits inside and makes a bigger single engine believable. PSR on the rest also makes progress, I am surprised and expected more resistance:
This afternoon, the wings were added, as well as the stabilizers and the canopy (will be closed because, for an open cockpit, the fuselage has to be cut since the clear part is actually only the clear part on the aircraft  :-\).
Offline PR19_Kit
  • What-IF SIG
« Reply #5 on: June 14, 2020, 08:54:03 am »
I didn't realise the twin engined ones were actually longer than the others.
You learn something new etc etc.  :thumbsup:
Offline Dizzyfugu
« Reply #6 on: June 14, 2020, 09:47:27 am »
Yes, the Yankee was based on the (longer) trainer airframe.
Offline Dizzyfugu
« Reply #7 on: June 14, 2020, 11:28:45 pm »
An addendum from day #2: finishing touches to the hardware. Still some details to go, but I expect external painting to start today (day #3).
I eventually found a suitable jet pipe implant: a protective cover from a syringe needle. Right size, and looks interesting enough.
Offline Old Wombat
« Reply #8 on: June 15, 2020, 03:04:26 am »
OK, so, at the time I type this, Dizzy has probably already completed this build & is well into preparing his second. :wacko:
Offline Dizzyfugu
« Reply #9 on: June 15, 2020, 04:28:10 am »
Nah... I actually did this stunt some years ago, but I take my time with the G.91X.  ;)
Offline Dizzyfugu
« Reply #10 on: June 15, 2020, 10:35:39 am »
Day #3: basic painting has started, and suitable, light ordnance has been selected:
The LAU-19 pods come from an Italeri A-4M, the 2nd hand Snake Eye Mk. 82 bombs from an ESCI A-7, IIRC.
One inspiration for this model were pictures from a PC-7 trainer of the Guatemala Air Force, which carried a livery in three murky shades of green. I found this paint scheme pretty interesting, esp. as an alternative to the ubiquitous SEA scheme (that Honduran A-37s carried). For the G.91X I adapted the scheme with slightly more contrasty tones of two shades of green and a more brownish hue: Faded Olive Drab (Modelmaster #2051), Olive Drab (Humbrol 155) and Dark Green (Humbrol 30). The undersides were painted in a light grey (Humbrol 166, RAF Light Aircraft Grey).
I initially considered a wrap-around scheme, but eventually found it to look too boring – also with a look at the potential markings, because aircraft of the Honduran Air Force typically only carried and carry minimal markings. Instead of the Guatemalan PC-7’s apparently symmetrical scheme I rather went for a more disruptive pattern, though.
Conveys some jungle feeling, I hope?
Sad news: I had to remove the exhaust pipe. While the size and shape were great, the plastic would not bond with the glue and the fuselage, so that a replacement is in the works.
Offline kitbasher
  • Moderator
  • bashes kits
« Reply #11 on: June 15, 2020, 01:49:55 pm »
Neither did I.  Now I understand the logic behind the build.
On the go: Arrow/Beaumaris/Battle/Bronco GA.1/Barracuda/CASA 2.217/Corsair GR1/EE P12/Fw190D-15/Hawker P1104/Hawker P1067/Hellcat IV/Ice Cream Tank/JP T4/Jumo MiG-15/Ki-61/Phantom FG1/Puffin/Sea Hawk T7/Spitfire XII/Ta154/Val/Spitfire 25/FrankenCOIN/Twin Otter
Offline Weaver
  • What-IF SIG
« Reply #12 on: June 15, 2020, 02:07:43 pm »
The G-91Y had longer-span wings too.
Neophyte: Is Eris true?
Neo: Even false things?
Neo: How can that be?
Principia Discordia
Twitter: @hws5mp
Offline PR19_Kit
  • What-IF SIG
« Reply #13 on: June 15, 2020, 02:13:43 pm »
They did something right then.  ;D ;)
Offline ChernayaAkula
  • Deutscher Meister 2011 & 2012 - BVB 09!
« Reply #14 on: June 15, 2020, 09:50:09 pm »
Nice colours.  :thumbsup:
