Author Topic: JPS Blanik L-13  (Read 1689 times)
Offline Tophe
    • my what-if models
Re: JPS Blanik L-13
« Reply #15 on: January 25, 2019, 07:54:33 pm »
beautiful! :thumbsup:
Offline TheChronicOne
  • -Sprues McDuck-
Re: JPS Blanik L-13
« Reply #16 on: January 25, 2019, 08:58:35 pm »
Heeeeelllllll yeah!!!! Look here!! I've been missing out. This is great!! 👏👏👏👏👍👌🔥🔥🔥
Offline zenrat
Re: JPS Blanik L-13
« Reply #17 on: January 25, 2019, 09:51:44 pm »
My name is Commander William Riker.  Take me to your women.
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
Re: JPS Blanik L-13
« Reply #18 on: February 20, 2020, 06:48:12 am »
I dunno what happened to this build, it just sort of petered out.  :-\
I just found it while looking for the missiles for my Canberra F10, and it's still in the state pic'd above. Needless to say I can't find the canopy bits yet, but it's a good candidate for finishing off.
  • -Sprues McDuck-
Re: JPS Blanik L-13
« Reply #19 on: February 20, 2020, 10:34:57 am »
Sure is.... wouldn't take much to cross the finish line, I suspect.
Offline Hobbes
  • Stores peanuts in his mailbox
  • What-IF SIG
    • Acme Engineering
Re: JPS Blanik L-13
« Reply #20 on: February 20, 2020, 12:06:48 pm »
So much for getting paint on the Blanik today.  :banghead:
I've got all the main parts assembled now, minus the cockpit and canopy of course, but the port wing was a TOTAL pain. Special Hobby's 'no locating pins' moulding system falls apart when you're dealing with long wings, and the Blanik's surely are long! The inner surface of the wing is curved to match the fuselage, and the first wing can be glued quite sensibly by turning the fuselage so the wing is vertical while it dries, but you can't do that with the second one as the first wing is in the way.
I found two ways to deal with that:
1. place two identical cardboard boxes on a table, with a gap between them just wide enough to fit the wing.
Place the model, with the fuselage resting on one of the boxes, and the first wing hanging in between the boxes. Adjust the model's angle to suit, and fix the angle (using blue-tac, shims under the tailplane, clamps etc.).
This gives a reasonable platform to work on attaching the second wing.
I also do this for fuselage decals on airliners etc.
2. the same idea, but using Lego as scaffolding.
Offline PR19_Kit
  • What-IF SIG
Re: JPS Blanik L-13
« Reply #21 on: February 20, 2020, 12:29:00 pm »
That's a similar idea to that which JayBee used on his  tiny 1/144 Blanik build.
I'll give it a try next time, thanks Harro.  :thumbsup:
Offline NARSES2
  • Global Moderator
Re: JPS Blanik L-13
« Reply #22 on: February 26, 2020, 05:53:56 am »
Would you like this moving Kit ?
And where were you in Durham by the way ?
Decals my @r$e!
Offline PR19_Kit
  • What-IF SIG
Re: JPS Blanik L-13
« Reply #23 on: February 26, 2020, 08:23:21 am »
Yes please Chris, it's WELL past the GB's end date!
I was staying in Newton Aycliffe and 'working', if you can call being a train guide working, in Shildon at the Locomotion Railway Museum.
Offline NARSES2
  • Global Moderator
Re: JPS Blanik L-13
« Reply #24 on: February 27, 2020, 06:18:22 am »
Right I'll move it now.
I was just up the road in East Boldon. Haven't been to Newton since I retired. British Steel used to have a works there. Narrow Strip I think ?
Anyway I shall move it now  :thumbsup:
Decals my @r$e!
Offline Scotaidh
Re: JPS Blanik L-13
« Reply #25 on: February 27, 2020, 08:58:06 am »
I used to attach the wings to the fuselage halves, like this:
Then I'd glue the fuselage halves together, supporting the wing tips as necessary.
I don't say it's the best way, but it worked for me.
I try to learn from the mistakes of others who take my advice.
Offline Captain Canada
Re: JPS Blanik L-13
« Reply #26 on: February 27, 2020, 12:07:46 pm »
Looks pretty slick in black !
Offline PR19_Kit
  • What-IF SIG
Re: JPS Blanik L-13
« Reply #27 on: February 27, 2020, 12:17:35 pm »
That was the general idea. It'd have looked even better if I'd have finished it!  :banghead:
Never mind, it's back on the 'Build Me' pile now.  ;D
Offline chrisonord
  • DIDN'T READ THE QUESTION PROPERLY
  • Paint it gloss??......HOW DARE YOU!!!
Re: JPS Blanik L-13
« Reply #28 on: February 29, 2020, 05:03:05 am »
I think it would be better with  GPS decals on instead.  Gary  Powers  Special  Blanik ;D
Offline PR19_Kit
  • What-IF SIG
Re: JPS Blanik L-13
« Reply #29 on: February 29, 2020, 05:08:43 am »
 ;D ;D
I'd have to find space for a camera then, and Blaniks aren't exactly roomy inside...  :o
