avatar_MichelC
Bachem 349 Natter, 1/48
Started by MichelC, August 27, 2018, 08:23:35 AM
Quote from: MichelC on September 29, 2018, 01:41:28 PM
After assembly the round front part was cut and sanded flat as can been seen on some of the Natter photos, the main reason being to make it easier to apply the decals in that area.
GOOD thinking!  :thumbsup:
MichelC
Thanks, Kit!
I started work on the launcher with the pole.
First a base coat of Gunze H66 Sandy Brown was applied. Then for the wood effect, Vandyke Brown oil paint was applied straight from the tube, no thinning, and then smeared and partially removed with a dry, clean soft brush.
To add variation, after 24 hours of drying time, more oil paint was removed with a cotton bud moistened with white spirit. Then the airbrush was used to lighten some areas with highly thinned base coat color. Similarly Tamiya Smoke mixed with Gunze Black was used to add some dark patches.
A coat of Future was applied to protect the work done so far and an oil wash (Vandyke Brown + Black) was then applied, which worked well with the kit's engraved wood veins texture.
A coat of Vallejo flat clear was followed by dry-brushing with Vallejo Medium Sea Grey.
The hooked spikes were painted with Vallejo Natural Steel followed by a black oil wash to dull the metallic shine.
In a slightly different lighting:
I'm quite satisfied with the result. Hope you like it too!
M
Like it? I love it!  :thumbsup:
How long is it though?
Quote from: zenrat on October 12, 2018, 04:36:20 AM
Wow, looks like a real one.
Yup. I'm always impressed by people who can do good wood effects and this is up there with the best  :thumbsup:
Quote from: MichelC on October 12, 2018, 06:30:48 AM
Kit, it's around 30cm long.
Wow, that's pretty hefty.  :o
Should look great with the Natter mounted on it.
MichelC
Yeah, one of the reason I like this model is cos the display is going to be higher than it is long, which is rather uncommon. Let's see how this all turns out, though. Next up: the metallic framwork of the launch system.
M
