Author Topic: Reverse history?  (Read 4434 times)
Offline The Rat
  • Proud Designated Pervert
  • Rivets? We don't count no stinkin' rivets!
    • http://www.bebo.com/Profile.jsp?MemberId=3947338590
Re: Reverse history?
« Reply #15 on: April 22, 2018, 07:08:15 pm »
Took ages to do this foil finish on the top of just one horizontal stabiliser. Never done this before, still low on the learning/swearing curve. Foil sections are laid at different angles to show textures of different panels.
Pineapple is a great pizza topping. Fight me.
Offline zenrat
  • Moderator
« Reply #16 on: April 23, 2018, 04:26:21 am »
My name is Commander William Riker.  Take me to your women.
Offline The Rat
« Reply #17 on: April 28, 2018, 04:28:15 pm »
Coming along slowly, panel by panel. Doesn't look great, but a lot better than I expected for my first try. Tip: Listen to The Sex Pistols, or similar, while doing this. It gives you a devil-may-care attitude that allows you to forge ahead with brutal lack of concern for a mistake. You can always learn how to correct one.
Offline Rick Lowe
« Reply #18 on: April 28, 2018, 05:52:03 pm »
Cool, looking good  :thumbsup:
From the "Just Make it Work and Get it Finished" School of Modelling, this gem:
Quote:
... (an) attitude that allows you to forge ahead with brutal lack of concern for a mistake.
Unquote
I'm going to have to remember that, too - see what you lot are doing for/to my lexicon/vocabulary?  :lol:
Offline zenrat
  • Moderator
« Reply #19 on: April 29, 2018, 04:30:10 am »
What foil are you using?
Offline The Rat
« Reply #20 on: April 29, 2018, 08:11:31 am »
Just regular kitchen foil.
Offline The Rat
« Reply #21 on: April 29, 2018, 03:01:12 pm »
Might be getting good at this. Decided on a metal finish after the intakes had been glued on, so how the hell do I get foil on the fuselage behind them? Eyeball it, cut a rectangle of foil, cut a V notch in it to get around fuselage attachment, test fit, adjust with sharp blade and curved scissors, test fit again, thank eyeballs for doing good work, then apply glue, wait until it's a little less tacky than normal, easier to adjust by sliding, then plop it in, adjust position, and burnish down. Came out pretty good on each side. Still some trimming and burnishing to do but the hard part is over with.
Musical accompaniment to stoke the 'screw it and forge ahead!' attitude is courtesy of a metal/goth playlist that someone put up. Cradle of Filth, Ghost, Type O Negative, Dimmu Borgir, Behemoth, a long list of throaty screamers. Includes the infamous uncensored video of COF performing From the Cradle of Enslave. Look that up at your peril.
Offline TheChronicOne
  • -Sprues McDuck-
« Reply #22 on: April 29, 2018, 04:55:25 pm »
Coming together!!!   I also enjoy ear bleeding devil music.  :wacko: :wacko:
Offline The Rat
« Reply #23 on: April 29, 2018, 05:25:06 pm »
Cut off the rounded U-2 nose, and replacing it with the pitot tube from the old Airfix Hawker P.1127, makes it look more Starfightery.
  • -Sprues McDuck-
« Reply #24 on: April 29, 2018, 05:56:32 pm »
That looks glorious!  I concur with this decision.   :mellow: :mellow:
Offline ysi_maniac
  • Kit Surgeon First Class
« Reply #25 on: April 29, 2018, 08:24:57 pm »
This is going to look awesome, ... perfect, ... brilliant. :bow: :bow: :bow:
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #26 on: April 29, 2018, 10:28:43 pm »
That pitot fits very well.  :thumbsup:
Offline zenrat
  • Moderator
« Reply #27 on: April 30, 2018, 03:10:37 am »
That explains it.  You are doing it the hard way.
Offline NARSES2
  • Global Moderator
« Reply #28 on: April 30, 2018, 07:39:21 am »
Beat me to it Kit
Decals my @r$e!
Offline Snowtrooper
« Reply #29 on: May 01, 2018, 01:53:58 pm »
Just out of interest (not that I'm planning to foil a NMF kit, but who knows...), what glue are you using? PVA glue, superglue, something else?
