avatar_strobez
Porco Rosso - Curtiss R3C-0
Started by strobez, March 04, 2018, 08:33:34 PM
strobez
Just a start, but I decided to tackle a couple more of the Porco Rosso planes.  Now that I've got the Savoia S.21 and Macchi M.52r on the shelf, they look a bit lonely.  So first up is the iconic blue Curtiss R3C-0 - basically the main "bad guy" plane of the movie.
So far I've managed to cut some sprues...
And get a first coat of paint on the bits...
Thanks!
I've built one of these.  Can't remember doing it so it must go together OK.
I painted the yellow and white markings as I was concerned about the opacity of the decals and wanted the yellow on the wings and rudder to match that on the underside of the floats.
nighthunter
I really want to build the Curtiss
strobez
It really is a dream to fit together. If I'd been able to get my masking tape straight on the seat cushion, I'd already have it buttoned up and pretty much fully assembled.
Thanks!
Even rigging it was easy.  2 lines each side from floats to wing.  If there was supposed to be interwing rigging I didn't bother.
KiwiZac
One of my favourite Cary Elwes roles. I'm excited to see this!
Zac in NZ
https://linktr.ee/zacyates
strobez
Well the cockpit went together without too much fuss (and none that wasn't of my own making). I plan to do a bit of rigging, pretty much in line with how it appears in the anime film.  I learned from my experience with my Tintin Ki-10 Perry to make sure the wing struts are glued in place before the painting starts otherwise you're just asking for a gooey mess.
So she's starting to look like a plane now...
Thanks!
strobez
A bit of a bulk update.  This one has been basically going together so smoothly that I keep forgetting to take/post any pics.
Once the construction was together, I gave it a coat of primer... no real flaws.  That's a first!  I was so excited I decided to do the white and yellow stripes first.  Seemed reasonable that the blue would cover any overlap better than the other way around.
The wing/pontoon struts are a lighter shade of blue, so I just masked off the stripes and then gave the whole plane a coating... that way it would give an even undercoat. I've had issues with blue showing the undercoat very well in the past, so I wasn't taking any chances.
Then I just masked off the struts and gave the rest of the fuselage a shot with the dark blue.  I had a little bit of an overspray issue on the floats, but nothing a bit of careful masking and another few shots of yellow couldn't fix!
Thanks!
This is really going to be the business  :thumbsup: :thumbsup:
Isn't masking the yellow on the underside of the floats a complete and utter c-word of a job.
