Author Topic: (DONE, PICS Pg. 4) BF-109 G6 Trop.  (Read 27305 times)
Offline TheChronicOne
  • -Sprues McDuck-
« on: May 15, 2017, 01:21:18 pm »
 ;D
WITH.... TOP SECRET PAINT JOB!  To be revealed in closing hours of the build.  :lol:
OK, check this out.... I was looking through all my kits for something either bagged or missing decals or some other affliction when I found this poor decapitated feller:
Found some decorations to make this stuff work:
Good to go!
OK, so, I have to come up with some bovine excrement to go with the plane and the paint job,  how it got where it is and came to look the way it does, and came up with a "Continental Gustav" theme. As a secondary sub theme and tie-in with another part of the story, also, the "Forgotten Gustav."  (this secondary theme will be explained at the same time as the paint job because it all ties in together.. it'll all make sense at that point... and "forgotten" will make sense and you'll see why it's important to the overall story! )
So, basically, in 1943 the Germans wanted some solid testing done on their tropical stuff and seeing how nothing like that environment was anywhere near Europe or N. Africa, they decided to "loan" some to Japan so they can use them in their conquest of SEA and adjoining area. Hot, humid, salt water all over the place, sand, and everything the glorious sub continent has to offer. Perfect place to test tropical equipment!
Anyway... so a squadron of G6trops make their way from one side of Eurasia to the other only to have them all fall (in mint condition!!!) into the hands of the 14th Army (tie in). A bunch of Indian guys find the not all too well hidden airplanes and hand them over to the 3rd Tactical Air Force of the RAF SEACommand.
This kit looks really easy to put together and that is what I wanted. I'm sure there'll be some sanding and stuff. I bet a great many of you have built this very kit in the past! I haven't built a 109 in 25 years. Not since I was about 10 years old when I built this one, and it was different company I do believe (came in a Testors boxing with 3 other WWII planes) :
Should be fun!
« Last Edit: June 04, 2017, 11:04:24 am by TheChronicOne »
Offline zenrat
Mould for that one dates back to 1956.  That version released in 1973.
I'm pretty sure i've built one at some stage back in the dim mists of antiquity as have most of us probably.
  • -Sprues McDuck-
Wow, 1956 huh!!  Here's the thing, the plastic all looks molded really well, not a lot of flash... Ive been test fitting and sanding a bit and the stuff seems to go together well... should be a cakewalk.
  • -Sprues McDuck-
OH BY THE WAY.... I know I can do this without but I imagine having access to the instructions for this could save me some time so if anyone has them scanned or knows where I can find them on the net, I'd appreciate it. I did a cursory web search yesterday but gave up a few minutes in as the research was far more interesting at the time.  ;D
Offline zenrat
Can't help you with that Brad C.  Sorry.  I only have the instructions from the newer version when they made a new tool.
Here's the original blister pack art though.
  • -Sprues McDuck-
Oh man, that's lovely!!
Not too miffed about the instructions... barring not finding the actual ones, I'll look around for a "review" or build page of the kit and follow along with that as I go.  Probably won't need any of it but it's still nice to have!
Offline loupgarou
Offline NARSES2
  • Global Moderator
Memories  ;D I built at least 10 of those when I discovered my first after market transfers (and they were called transfers back then) in BMW's in Wimbledon. My first purchases were a sheet of swastikas (which I still have and are still usable) and a couple of sheets for different countries 109's.
Decals my @r$e!
Offline dwomby
  • Kitbasher
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
IIRC the original Airfix Me-109G came in a plastic bag with the instructions stapled to the top, like the J-EJ Spitfire IX. The bubble pack version came later on.
  • -Sprues McDuck-
Try a look here:
http://www.cavallar.ch/model/
SUPERB!!! I love this site.  Bookmarked and was able to find the instructions in less than 3 minutes!
  • -Sprues McDuck-
There are images of the instructions you want here: http://americanscalemodel.freeforums.org/airfix-1-72-bf-109g-blister-pack-t544.html
David
Glorrrrrious! Thank you! Perfect! Now I'm good to go!
Offline Rick Lowe
The Airfix Tribute Forum also have a library of kit instructions... not just the Airfix stuff, either.
http://airfixtributeforum.myfastforum.org/viewforum.php?f=280
Offline zenrat
I'm sure you would have had no problems building it without the instructions Brad C.  Pretty much SOP for a kit of that age.
Offline NARSES2
  • Global Moderator
Yup, and the plastic bag packed version was the one I had so many of  ;D Was never a fan of the bubble pack ones. Indeed not sure I ever had many. I was well into my wargamming phase by then
Decals my @r$e!
