avatar_darthspud2
2017 builds.
Started by darthspud2, April 07, 2017, 10:44:07 AM
Quote from: Old Wombat on July 02, 2017, 10:48:35 AM
Quote from: PR19_Kit on July 02, 2017, 10:30:06 AM
Quote from: Scotaidh on July 02, 2017, 09:53:45 AM
The only quibble I have is that the back-seaters seem to be facing forward - should they not be facing the rear, in true British fashion?  ;)
Tut, tut, that's only aboard transport aircraft.............
And makes a lot of sense for passenger survivability in a crash. Civilian passenger aircraft only have the seats facing forwards because people feel more comfortable doing that.
For a while BEA, and subsequently BA, had rearward facing seats in the first three rows of their Trident 2 fleet. I'm not sure why, but I always tried to get a seat in the rearmost rearward facing row or the foremost forward facing row as there was much more leg room in that transition area.
With the take-off performance of the Trident sitting facing the rear wasn't too much of a problem.........  ;D
darthspud2
My rear seaters are flight crew training seats,
so seats for re-qualling grounded crew maybe or as a second crew space with a crawl space to allow in-flight crew change over.
I think I'm gonna need a bigger display cabinet!!
Quote from: PR19_Kit on July 02, 2017, 11:01:37 AM
Mrs kitnut's Dad was in the Brit Army, and he got himself overseas posting for much of Mrs kitnut's younger life (that's until she met me  ;D ). She has told me that whenever they flew to a new posting (Hongkong, Germany) she went on an aircraft which had all the seats facing backwards. I tried to quiz her on what aircraft it was but she wasn't able to tell me. I'm guessing VC10s
Snowtrooper
Quote from: darthspud2 on July 02, 2017, 02:23:43 AM
More to follow, just another 6 in build process or stash unbuilt.
Running out of ideas though (ish)
Looking at the thread, I guess you want them to be British ones?
  • Aggressor but in British service
  • Battle of Britain commemorative scheme (daytime with DG/DE uppers and either Sky or B&W lowers; you already had the Tyfie in nightfighter black)
  • Cold War natural metal high-visibility retro scheme (Tiger Squadron is always relevant)
  • A-16A in the "two greens" camo used by RAF Harriers in the 1980's, ADEN centreline pod instead of the GPU-5/A, etc.
  • RF-16 with camera ports in the nose and British linescan pods etc.
  • Navalized Viper (Vought Model 1600) for the FAA (you could steal the idea of Sparrow/Skyflash/AMRAAM/Meteor rails on MLG doors to any other build, too)
  • Late-block Gen 4.5 Viper with stealth features, canards, 2D TVC or LOAN nozzle, DSI, radar-absorbing metallic paint, the works, see for example DFZ's "F-16W" thread for inspiration
  • Delta-winged Viper - while the XL kit is a bit hard to find and you already have six regular Falcons in the stash, how about Draken's or Viggen's wing instead of straight delta?
  • F-16 FSW - again, just reversing the standard wing and adding a bit of forward sweep to the former trailing edge might be more economical
  • If you're swapping wings, then there's Modelling Mushi's F-16/Starfighter kitbashes to give you inspiration
  • F-16 CCV if you just want to insert canards under the intake
Quote from: Snowtrooper on July 03, 2017, 01:26:39 PM
Any of those suggested would be very nice to see!! Get those Vipers going!! :thumbsup:
darthspud2
Snowtrooper,
First 3 in your list are built or in process of build.
I don't post build pics at the moment, too much other stuff going on.
The Lizard Scheme/RAF Version is also about to make an appearance
Watch this space!!
Quote from: kitnut617 on July 03, 2017, 12:41:21 PM
The French Sud Caravelle had a mixture of rear and front facing seats.
darthspud2
Now I really am not a F.16 fan but you could ALMOST make me reconsider  ;) :thumbsup:
darthspud2
#39
None of those are visible I'm afraid.
darthspud2
look ok from the various pc's I log in on?
I canna see them either.
Quote from: darthspud2 on July 14, 2017, 02:09:32 AM
Yes, but it knows you're you, and maybe it won't let others see them anyway, or else it needs some settings changed to enable that.
All I see's a column of commas. :unsure:
