avatar_Ify
An Ify Bridge
Started by Ify, April 07, 2017, 05:27:36 AM
Ify
Quote from: Old Wombat on March 01, 2018, 01:52:19 AM
And he's a flippin' boat builder! Are there no end to the man's talents? :o
Ha ha ha, your funny. Thanks for the compliment.
________________________________________
Determined the waterline and marked the bulkheads. Used the cabin ceiling as the horizon.
Then planked the waterline, and laid in the planks in between.
Then filleted the boat like a fish and sanded the bottom flat and smooth.
Captain: The future is in your hands, Scotty.
Scotty: But Captain, I can't change the laws of physics.
Ify
Thanks NARSES2.
________________
Making extras that the kit does not provide, plus preparing some of the parts for next step.
Two sets of red-green navigational light hoods. One for upstream and other for downstream.
Added winch drum and a hand crank. Adding a deckhand, sitting on a box.
Stained the doors, and later the cabin roofs, with coloured ink.
Added bits of copper wire to look like door hinges.
Painted spare life-savers to look like bumper tyres.
Unravelled some string to make the deckhand appear to be splicing a rope.
Used some wood putty and sanded the hull smooth. It will be painted.
Made rigging eyelets from a paper clip and attached them to their appropiate places.
I showed some of these pictures to my brother who was a shipwright on the Wear. He was suitably impressed  :thumbsup:
Ify
Thank you NARSES2 for your compliment.
Made several LED cables. All LEDs are 3 mm and clear until lit. It makes for less confusion especially for the red and green nav lights.
Only one LED lead needs sheilding for insulation. The black mark on lead is to tell me which is the LED cathode (K)/(-).
Used the end of a pen as a beacon housing.
Added copper wire railing on cabin roof.
The front cabin walls were too thin to contain any interior lighting. Made a light shield and reflector to compensate.
Made stern light hoods. Added nav light hoods, and a radar unit.
Squizzette
That's some excellent work. It's nice to see a project like this coming together.
"So many ideas, so little talent" ;)
Ify
Thank you Squizzaa.
Added some humour to the scene.
You need a scale worksafe inspector in hiviz with a clipboard.
Guy in the blue shirt almost looks as though he's just about to bowl a full toss in one of the pictures  ;D
Lovely work  :thumbsup:
For the non cricketers amongst us (Heathens  ;)) https://en.wikipedia.org/wiki/Full_toss
Ify
Quote from: zenrat on March 09, 2018, 12:40:53 AM
Ho ho ho :laugh: and coming from the other bow section.
Great idea. Thanks. I might use that with the other council workers.
Ify
Quote from: NARSES2 on March 09, 2018, 06:08:03 AM
Guy in the blue shirt almost looks as though he's just about to bowl a full toss in one of the pictures  ;D...
:laugh: Sure does look like a cricketer, who went over the line but didn't want to.
Ify
The boat is to be placed on a base plate. The plate is attached to the aluminium vane that goes through the table to the pulley-cable system.
Four electrical connections need to be part of the 2 mm thick vane. These will provide both power and signals to the boat lighting system.
The electrical connections are via a printed circuit board, which is 0.5 mm thinner than the vane.
So it has some clearance away from scraping along the slot in the table.
This portion of the project is on hold, until certain parts become available.
In the meantime, the boat needs to be rigged.
Ify
Shouldn't you use a palindrome for the boat's name? Like Glenelg, or Madam Adam, or Rotator? :unsure:
Good job, by the way! :thumbsup:
Ify
Quote from: Old Wombat on March 20, 2018, 07:03:32 AM
:laugh: That is a good idea missed.
Though the boat name, Bingal, does have some connection to a play on words.
Bingal, was the original (Aboriginal) name for Wardell, where the actual bridge is located. The name is close to the word bingle, meaning a collision. In this case a collision of two bow sections. As a hidden emphasis, there is a bingle, on the Bingal, by the deckcrew.
