avatar_TheChronicOne
Sanding: Wet or Dry?
Started by TheChronicOne, January 21, 2017, 01:27:03 PM
Preferred Method
Wet Only
Wet and Dry Both, Depending on the Situation
Dry Only
Dork the kit slayer
Mainly wet ,with lots of soap. Using all grades. The sludge helps polish the surface as well as removing debris.
Same here, mostly wet with a wee bit of washing up liquid.  I find it sands better and helps keep the dust down as I do my modelling in the living area.  I only really use dry for quick jobs when it's a few passes finish the job and it's not worth filling a pot up.
I'm certainly going to be doing a lot more wet sanding from here on out. The dish soap is a nice tip!
