avatar_Freightdog862
What do you want from Freightdog? suggestions needed....
Started by Freightdog862, September 15, 2016, 12:10:08 PM
I'd have one of those.  I've had one on the go for years but I've never done anything more than chop the nose off the PM kit.
Probably not doable in time for Telford, but what about the BAe SABA? It'd be a whole model but it was a relatively small aircraft.
http://www.abovetopsecret.com/forum/thread186160/pg1
Although the project most people associate with SABA was the pusher-propfan P.1233-1. the P.1234-1 or -3 would probably be the easiest to mould.
Vokes or Aboukir filter for the new Airfix Spitfire Mk V. Not sure if it's out yet ?
Spit is on Hannants today. It's the 2010 tooling with new transfers
Also perhaps some of the early lighter bombs - up to 250lb - used by the RAF ? Aerial mines, depth charges and torpedoes ?
Quote from: Weaver on September 16, 2016, 05:12:11 AM
TSRJoe has already done the SABA both  the jet and the turboprop versions.
Quote from: JayBee on September 16, 2016, 06:46:41 AM
Yeah, but how/where do you get one?
Jet ?
The P1234-2 is one of my Scratch-builds  ;D
Since Freightdog already does a range of Buccaneer parts, how about a Green Cheese/Cockburn Cheese missile for it? Wasn't the same weapon also proposed for the Valiant at one point?
Quote from: Weaver on September 16, 2016, 08:08:25 AM
Freightdog did the Buccaneer Green Cheese
Quote from: Thorvic on September 15, 2016, 10:25:08 PM
Quote from: Weaver on September 15, 2016, 10:12:43 PM
Well the thing I've always wanted to see SHOULD be simple and that's the SRAAM-100 twin missile pod as developed in the UK from the late 1960s through the late 1970s. It was test-flown on Hunters and mockups were fitted to Harriers and probably many other types. I know that there's an issue finding references for it but surely somebody must have drawings? There's an actual pod in the Bristol collection, so may they have documentation too?
https://en.wikipedia.org/wiki/SRAAM
It has been suggested in the past and Colin did get it looked into but was lacking Photos of the underside which held them back. A pity as its a cracking little add on that can be used on various types in place of Sidewinders or ASRAAM. I know Hobbes scratch built one as he went to Bristol to see it so might have the necessary info.
I have the same problem as Colin: no info on the underside. And with the Bristol museum closed there was no way to access the original. They're opening a new venue next summer, I'll give this another go then.
Vlamgat
Quote from: Hobbes on September 16, 2016, 11:22:44 AM
Yeah, I was going to say that. Their website makes a big deal of their archive and records facilities, so maybe that'll prove useful.
