avatar_Lrrr
FW 190G / A-10 in Aluminum
Started by Lrrr, September 03, 2016, 07:32:15 AM
Blimey, and I thought a Napier Sabre was complicated... :o
It's specific output wasn't that good, was it, considering it was almost two Merlins worth of capacity for about the same horsepower?
wuzak
Quote from: PR19_Kit on October 05, 2016, 08:39:25 AM
Look at it this way - its capacity was similar to the R-3350 and it generated about the same amount of power as the R-3350 did at that time. And the R-3350 was, indeed, around twice the capacity of the Merlin.
Lrrr
#17
Update:
Wings from Ta 152H have been grafted onto a FW 190A-8 fuselage.  The lines aren't perfect, and it took some silly putty filler, but overall not bad for some major surgery.  The larger wing also came with a larger wing box.
The tail is extended, though not to full length of the 152.  It was a bit too stubby with the A-8 tail.
I'm going with the "Graf" graphics.  More to follow.
I am Lrrr.
Quote from: Lrrr on October 07, 2016, 11:30:38 AM
Way to go!  :thumbsup: :thumbsup: :thumbsup: :thumbsup:
Lrrr
Quote from: PR19_Kit on October 07, 2016, 12:52:57 PM
Danke! <_<   I also went back and posted images instead of links on the first post.
I am Lrrr.
Lrrr
#20
My interpretation of what little is known about the FW 190A-10.
"Late in the war, the A-10 was fitted with larger wings for better maneuverability at higher altitudes, which could have allowed additional 30 mm (1.18 in) calibre, long-barreled MK 103 cannon to be fitted."
This is shown in aluminum with Hermann Graf markings ( "flames" ).
Keeping with the WHIF theme, this would actually be the Dz 702 powered long-wing B-10.
30mm Mk 103s with muzzle brakes on the inner wing stations.  13mm cowl guns now 20mm MG-FF-M.  While this particularly fighter would lack any fast-firing guns, the entire purpose of its existence is to target large bombers and hammer them with HE rounds.
Though with the high-altitude aerodynamics and deadly firepower, it would also be more than a handful for any allied escort or interceptor.
I am Lrrr.
Lrrr
#21
I am Lrrr.
