avatar_Gondor
Hawker Siddeley P.1121
Started by Gondor, July 06, 2015, 04:20:01 PM
Well it's another case of one step forward and two steps back. I did manage to fit the other tailplane last night, however I have had to cut off the locating wire I was going to use as it was way to thick in the end and I had the tailplanes become so loose that I had to remove and re-glue them!
Where the Light Aircraft Grey has shown up some faults with the PSR on the underside, the Dark Sea Grey has nicely covered the upper surfaces. It looks so nice I am almost tempted to simply mark it up in Royal Navy markings as part of FRADU  :blink: at least the good coverage means I can just add the Dark Green later today. Must really sort out the decals or all the effort will have been for nothing.
Good news/ Bad news ! Looking forward to seeing how you finish this one up.
Really feeling that I could have done with those extra weeks on this kit. Saying that I do have plans to build a two seater which will be more of a scratch build than this thing has been so I will have absolute control over how it goes together so that everything will be in the right place. I am sure the wings are at different heights on this and that's only one of the problems there has been with it  :banghead:
Getting there. Glad there is not much in the way of decals as there is some touching up to do as well as the obvious Radome to paint. Tires are painted and will get a Matt coat last thing tonight as I use Xtracolor Tyre Black which is a bit glossy neat but great when Matted down. As you can see in the background the "load" is ready and will be the last item added to the build.
Quite pleased with the way the cockpit has turned out. A lick of paint as it should be ok. Black to go with the interior where it has lifted or been damaged then grey for the canopy while leaving the windscreen black.
Quite pleased with the result so far
It looks a bit better now that the canopy is the same colour as the rest of the aircraft and the radome is black. It's going to get it's first coat of Klear this evening so I can decal it tomorrow, add more Klear and the wheels which I will Matt later tonight then its just add the wheels and the "load" and that's it finished!
Really looking the part now  :thumbsup:
I use Xtracrylic RLM 66 for a tyre colour on my post 30's aircraft. Don't matt it as I like the sheen. Looks a little more rubbery to my eye. Pre 1930 they can be anything from pale grey through black and even pink for some German WWI tyres
I am calling this finished. I don't know if the kit won or I did. I have had problems all the way through this build and right at the end my complacency about the fact I was at the end caused another problem that thankfully most people will not see or notice.
The picture below makes me think of the song "Fat Bottomed Girls" by "Queen"  :blink:
What was used is
Whirlykit's P.1121 multi-media kit
with additional items from
CMK's Buccaneer S Mk2 from which the Red Beard "load" came from
Academy 1/48 Hawker Hunter for the undercarriage nose leg
Revell 1/72 Hawker Hunter for two main wheels that made the new nose wheel
Aeries 1/72 F-105 replacement Wheel set for the Trumpeter F-105 which provided the main wheels
Paint was mainly Humbrol Enamels and Acrylics
Decals were by Xtradecal, Airfix, Matchbox and the spares box
TallEng
Considering the hard time it gave you, that's come out really well. :thumbsup:
Good show :cheers:
Keith
Looks good. I have no prior knowledge of this aircraft so I can't comment on accuracy but you did a good job.
Dihedral on the tail looks a bit odd but if that's the way they designed it then that's the way they designed it.
The Big Gimper
Wonderful build. As you noted, it was a battle of wills.
Work In Progress ::
Lots of stuff
Quote from: TallEng on October 15, 2015, 08:30:59 PM
Good show :cheers:
Absolutely....well done  :thumbsup: :thumbsup:
Another beauty ! Love the look of this one in her camo. Turned out really well. And as an aside we`ll be singing `fat bottomed girls`all day  :thumbsup:
Steel Penguin
looks good, for all you've said, a top notch job  :thumbsup:
Librarian
A very nice finish of a damn difficult build :thumbsup: :thumbsup:. Vacuforms terrify me.
Depending on the angle, I'm seeing Crusader rear, shades of F-107....lots of things. Fascinating aircraft.
