avatar_Gondor
BoB Spitfire
Started by Gondor, June 22, 2015, 11:43:57 AM
Dogfighterzen ... i decided to take a look at what you said about the longest day and you nailed that one ...at first glance you might think they were P47's but when it shows another shot of the planes from the side as they pass a ship that tail is definitely Skyraider ,,damn well spotted matey  :thumbsup:
Gondor mate ,,oh its 1/72nd ... ok its better now  :lol: ,,that would look good in 32 nd but looks seriously kick arse in 72nd ..  well done again bud  :smiley:
Phill
KiwiZac
Quote from: Dizzyfugu on June 23, 2015, 09:45:21 AM
Quote from: zenrat on June 22, 2015, 05:50:34 PM
Nice job.
The Messerschmitts and Heinkels in the movie didn't look like Messerschmitts and Heinkels so why should the Spitfires have looked like Spitfires?
Second that. And it's even the better option than using a P-51 as an early Spitfire double...
How about using a Buchon modded to look like a razorback P-51?
Zac in NZ
https://linktr.ee/zacyates
Hmmmn.  Don't know where to start with this one.
The Heinkels and Messerschmitts were modded as much as possible to look like BoB aircraft.  The makers of the film took great pains to get the aircraft to look right.  To the extent of rebuilding Proctors to look like Stukas, removing cannon barrels and replacing rudders on Spitfire IXs and building up the spines of Spitfire 16s to get them to look more like mk Is.  Codes on the aircraft looked real but were spurious (although on checking, many of the RAF codes were actually station flights or training units)
They used what was available and did a fantastic job.  To accuse them of doing otherwise is to do them a grave injustice.
Which is why the model doesn't work for me at all.  They'd have modded it to get it to look closer and then used it in long shots - look carefully and you can see Buchons in RAF cammo and PR19 Spits in similar colours.
This is much closer the mark:
Quote from: Wardukw-NZ on June 23, 2015, 02:59:45 PM
;D Thanks for the confirmation!!  :thumbsup:
I thought of P-47s but as the movie is from 62, i thought the A-1s would've been more easily available for the movie than the old Jugs and then, the tail, the long drop tanks and engine cowling called it out.
Lee, it's what if and that's exactly how I build it. Simple and easy and straight out of the box with minimal change and basically a swapping of decals and paint scheme.
Quote from: Gondor on June 24, 2015, 02:27:26 AM
It's YOUR model Alastair, do it YOUR way.................  :thumbsup:
