Author Topic: Done: Supermarine Spitfire Mk. XVIe trop. of the Lebanese Air Force, 1951  (Read 4874 times)
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
Re: Supermarine Spitfire Mk. XVIe trop. of the Lebanese Air Force, 1951
« Reply #15 on: April 05, 2015, 02:01:52 pm »
I said he'd have it done by Tuesday, maybe make that MONDAY?
Offline Glenn Gilbertson
  • Had fish & chips in Hull once
  • Remembers when Airfix kits cost 2s (0.10)
« Reply #16 on: April 05, 2015, 03:42:49 pm »
I like it - good looking and plausible! :thumbsup:
Offline Dizzyfugu
« Reply #17 on: April 06, 2015, 02:13:06 am »
Finishing touches on Monday morning (e. g. soot stains, some oil and dry painting with silver e .g. around the canopy hatch) and a coat of acrylic matt varnish:
"One Week Group Build" at whatifmodelers.com: 1:72 Supermarine Spitfire Mk. XVIe Trop (Type 361); aircraft "١٥٤ ﻞ/L 154" of 2nd Squadron, Lebanese Air Force (LAF) (القوات الجوية اللبنانية‎/Al Quwwat al-Jawwiya al-Lubnaniyya); Rayak Air Base, 1951 by dizzyfugu, on Flickr
BTW: the plan had been to build this one as a plausible whif - it fits seamlessly into real world's history, wait for the beauty pics and the story... not certain if that is feasible today, but at least the kit will get finished and I might add first pics for the GB's gallery.  ;)
Offline Bungle
  • Don't call him Tinky Winky, Dipsy, Laa-Laa or Po
  • Targeted for assassination by JMNs
« Reply #18 on: April 06, 2015, 03:20:51 am »
Amazing ! Not just the speed but the quality.
I haven't even got the wings on mine yet !
"A child of five would understand this. Send someone to fetch a child of five." - Julius Henry Marx (Groucho)
Offline Captain Canada
« Reply #19 on: April 06, 2015, 03:54:42 am »
Gorgeous. Colours and markings look superb. Nice to see the prop housing as well, might have to try that !
Offline McColm
« Reply #20 on: April 06, 2015, 06:15:40 am »
Wow! :bow:
Offline NARSES2
  • Global Moderator
« Reply #22 on: April 06, 2015, 07:37:55 am »
There is no way my paint would dry that quickly  :blink:
There has to be a hole in the space/time thingamy gidgum ! I blame that Haldron Collider thing  ;D
Decals my @r$e!
Offline Dizzyfugu
« Reply #23 on: April 06, 2015, 08:05:20 am »
Finished! Quicker than expected (and THAT means something...  :rolleyes:), and here's the story behind it; I present to you a 1:72 Supermarine Spitfire Mk. XVIe Trop (Type 361); aircraft "١٥٤ ﻞ/L 154" of 2nd Squadron, Lebanese Air Force (LAF) (القوات الجوية اللبنانية‎/Al Quwwat al-Jawwiya al-Lubnaniyya); Rayak Air Base, 1951.
1:72 Supermarine Spitfire Mk. XVIe Trop (Type 361); aircraft "١٥٤ ﻞ/L 154" of 2nd Squadron, Lebanese Air Force (LAF) (القوات الجوية اللبنانية‎/Al Quwwat al-Jawwiya al-Lubnaniyya); Rayak Air Base, 1951 (Whif/Heller kit conversion) by dizzyfugu, on Flickr
Some background:
The Supermarine Spitfire is a British single-seat fighter aircraft that was used by the Royal Air Force and many other Allied countries during and after the Second World War. The Spitfire was built in many variants, using several wing configurations, and was produced in greater numbers than any other British aircraft.
The Spitfire was designed as a short-range, high-performance interceptor aircraft by R. J. Mitchell, chief designer at Supermarine Aviation Works (which operated as a subsidiary of Vickers-Armstrong from 1928). In accordance with its role as an interceptor, Mitchell designed the Spitfire's distinctive elliptical wing to have the thinnest possible cross-section; this thin wing enabled the Spitfire to have a higher top speed than several contemporary fighters, including the Hawker Hurricane.
It was the only British fighter to be in continuous production throughout World War II, and remained in service with several air forces around the world for several years. One of its post-war operators was the Lebanese Air Force, or Al Quwwat al-Jawwiya al-Lubnaniyya (لقوات الجوية اللبنانية‎).
The Lebanese Air Force was established in 1949 under the command of then-Lieutenant Colonel Emile Boustany who later became commander of the army. Soon after its establishment, a number of planes were donated by the British, French, and Italian governments, with additional planes donated by Britain and Italy later that same year.
Britain donated 4 Percival Prentices, 2 World War II-era Percival Proctors and seven trpocailized Supermarine Spitfires (six Mk. XVIe and one TR.8 two-seater), while Italy donated 4 Savoia-Marchetti SM.79 bombers which were mainly used for transportation.
The Mk XVI Spitfire was a WWII design, and the last variant powered by a Merlin engine and based on the original, sleek fuselage. It was basically the same as the Mk IX, except for the engine, a Merlin 266. The Merlin 266 was the Merlin 66 and was built under licence in the USA by the Packard Motor Company. The "2" was added as a prefix in order to avoid confusion with the engines, as they required different tooling.
All Mk XVI aircraft produced (a total of 1,054 Mk XVIs left Castle Bromwich) were of the Low-Altitude Fighter (LF) variety. This was not determined by the length of the wings (clipped wings were fitted to most LF Spitfires), but by the engine, which had been optimised for low-altitude operation. All production Mk XVIs had clipped wings for low altitude work and were fitted with the rear fuselage fuel tanks with a combined capacity of 75 gal. Many XVIs featured cut-down rear fuselages with bubble canopies. On these aircraft the rear fuselage tank capacity was limited to 66 gal.
Because of a slightly taller intercooler and rearranged accessories on the Packard Merlins a new, bulged upper cowling was introduced, a detail that also appeared on late production IXs. For the service in the Middel East region the Lebanese machines received dust filters which considerably changed the aircraft's silhouette.
Armament consisted of  two 20 mm Hispano II cannons - each with 120 rpg - and two 0.50 calibre Browning machine guns - each with 250 rpg. 1 500 lb (227 kg) bomb could be carried underneath the centre rack, and 1 250 lb (114 kg) bomb could be slung under each wing. As a special feature, the wing hardpoints of the Lebanese Spitfires were "wet" so that slipper tanks with 24 gal. each could be carried, compensating for the reduces rear fuselage tank due to the bubble canopy's lowered dorsal spine.
The Lebanese Spitfires only saw a short service, since in 1953, jet fighters were introduced when 16 de Havilland Vampire jets were received, and the first Hawker Hunters arrived in 1959, which replaced the obsolete Spitfires. This initial Hunter batch was followed by more Hunters through 1977.
In 1968, 12 Mirage IIIELs were delivered from France but were grounded in the late 1970s due to lack of funds. In 2000, the grounded Mirages were sold to Pakistan, and four Hunters were even revived in 2008 and served until 2014.
General characteristics:
    Crew: one pilot
    Length: 29 ft 11 in (9.12 m)
    Wingspan: 36 ft 10 in (11.23 m)
    Height: 11 ft 5 in (3.86 m)
    Wing area: 242.1 ft2 (22.48 m2)
    Airfoil: NACA 2209.4(tip)
    Empty weight: 5,065 lb (2,297 kg)
    Loaded weight: 6,622 lb (3,000 kg)
    Max. takeoff weight: 6,700 lb (3,039 kg)
Powerplant:
    1 Rolls-Royce Merlin 60 supercharged V12 engine,
    rated at 1.470 hp (1.096 kW) at 9.250 ft (2.820 m)
Performance:
    Maximum speed: 370 mph, (322 kn, 595 km/h)
    Combat radius: 410 nmi (470 mi, 760 km)
    Ferry range: 991 nmi (1,135 mi, 1,827 km)
    Service ceiling: 36,500 ft (11,125 m)
    Rate of climb: 2,600 ft/min (13.2 m/s)
    Wing loading: 27.35 lb/ft2 (133.5 kg/m)
    Power/mass: 0.22 hp/lb (0.36 kW/kg)
Armament:
    2x 20mm Hispano Mk II cannon (120 RPG)
    2x .5 in Browning machine guns (250 RPG)
    Three hardpoints (1 ventral, 1 under each outer wing) for up to 1.000 lb (454 kg).
I'll admit it's not a spectacular whif, and overall rather simple concerning build and painting. But it's a proud addition to whatifmodelers.com's "2015 One Week Group Build", even though this was already finished in just three days from sprues to beauty pics...  :cheers:
« Last Edit: April 06, 2015, 09:39:41 am by Dizzyfugu »
Offline JayBee
  • Won't go back to Hull again
  • What-IF SIG
  • "Aquilla non captat muskas"
In all aspects..........
 :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow: :bow:
Offline Supertom
  • Waiting on bits to show up in the mail
  • Administrator
  • I miss my Bovril.
May I propose that for future One Week Builds, that Dizzy is not allowed to participate and instead has to do Three Day Builds.
Offline kitbasher
  • Moderator
  • bashes kits
Or impound his time machine!
On the go: Arrow/Beaumaris/Battle/Bronco GA.1/Barracuda/CASA 2.217/Corsair GR1/EE P12/Hawker P1104/Hawker P1067/Hellcat IV/Ice Cream Tank/JP T4/Jumo MiG-15/Macchi MC.205/Phantom FG1/Puffin/Sea Hawk T7/Spitfire XII/Ta154/Val/Spitfire 25/FrankenCOIN
Offline Dizzyfugu
 ;D
Offline Nils
  • Belgium's "Iceman"
  • Execute in scale 144!
looks very, very good  :thumbsup:
hard to believe you finished this build in only a few days  :mellow:
ive build the Heller Kit to (converted it to a Belgian LF.14e).
a great kit, although a but fragile, but thats pretty much Hellers weak point.
Offline Supertom
  • Administrator
  • I miss my Bovril.
Hey Dizzy, have you done a how-to on photography? I've do like the way you do your photos.
