avatar_Army of One
My stash just grew again (2015)
Started by Army of One, December 31, 2014, 03:44:26 PM
Quote from: Howard of Effingham on January 18, 2015, 01:04:16 AM
btw, brother narses. I think you got a miss-packed set of instructions as the ones in my IVF were fine.
Not miss-packed but miss-printed (I used to know their sister mis-demeanor  :rolleyes:). The front page and back 2 are for the Blenheim, the rest for the Gnat
First kit of 2015 from the bay, Hasegawa's 1/72 F-20 tigershark for a Portuguese whiff.
from the discount store this afternoon:
2 x Revell 1/144 P-47D Thunderbolts (99 cents a piece  ;D )
Quote from: DogfighterZen on January 18, 2015, 12:11:23 PM
Nice! Would be a perfect A-7P replacement.  :thumbsup:
A set of scribing templates from Royal Model.
via eBay
Airfix 1/72 BP Defiant (new tool)
Looks a nice little kit  :thumbsup:
From the LHS.
1/72 Academy Catalina "Black Cat".  Comes with additional RAAF decals which I won't use as it'll be a civilian amphibian.  Possibly a turbocat.
From the Big H new tool Airfix 1/72 Defiant. Looks a delightfull kit  :thumbsup: Must admit I had no idea there was a night fighter with a shark's mouth  :o Also my initial reaction on seeing the transfer sheet was to think they'd got the rudder stripe blue way to light a shade. Then you look at the instructions and it says that photos of the aircraft would appear to indicate that this was indeed the case.
This will be a real world day fighter which I think is a very attractive looking option  :thumbsup:
Quote from: NARSES2 on January 21, 2015, 07:40:00 AM
In light of it's day-time short-comings, I wonder if mounting a couple of gun pods under the wing (like Hurricane Mk.IV's) with .5's or 20mm's would have been feasible -----  :-\
The Defiant had quite a high wing loading, especially compared to a Hurricane. Any more guns and it's turning circle may have exceeded the width of the Channel........
Quote from: PR19_Kit on January 21, 2015, 09:33:41 AM
Would that still apply if you removed the turret ? I ask because one of my MPM examples is slated as a single seat light bomber with bomb cells in the wings
Quote from: NARSES2 on January 22, 2015, 12:44:40 AM
That would improve it a lot Chris, that turret must have weighed a fair proportion of the overall weight of the aircraft.
Comparative figures :-
Hurricane (IIC) :- Wing area = 257.5 sq ft Weight max = 7670 lbs Wing Loading = 29.8 lb/Sq ft
Spitfire (Vb) :- Wing area = 242.1 sq ft Weight max = 6622 lbs Wing Loading = 27.4 lb/Sq ft
Defiant (Mk I) :- Wing area = 250.0 sq ft Weight max = 8600 lbs Wing Loading = 34.4 lb/Sq ft
And all that added weight of the Defiant is in the structure, it didn't carry more fuel etc. apart from the extra weight of the gunner.
Also have Pavla Defiant that lost its turret (to a Wellesley), and now it waits for a decent idea for a conversion.
P.96?  Defiant with Sabre or Centaurus (or anything else), fixed armament was investigated. There was an earlier P.88 with the Vulture or Hercules offered (the Hercules powered version had a deeper fuselage).  Basically, beef it up with a powerplant of your choice, since you've not got the turret fair the spine in to make a single or two seater.  Either that, or loose the spine altogether and add a bubble canopy.
There was an earlier P.88 too, with the Vulture and Hercules offered:
