Author Topic: My stash just grew again (2015)  (Read 110598 times)
Offline Dizzyfugu
Re: My stash just grew again (2015)
« Reply #30 on: January 05, 2015, 07:51:42 am »
First entry - even though ordered last evening, still in 2014: a pair of Hobby Boss Bf 109 G-2s. The recent Whirlwind conversion gave me an idea for a German "Wirbelwind"...  :rolleyes:
Wouldn't it be easier to cut down a Me-110 ?  ;)
Perhaps a Me410, instead?
Probably better off starting with an MPM 109H with the extended span, possibly the reboxed Face 109T as an E which gave you two wings?  Whirlwind wasn't much larger than a Spitfire. 110 is more of an enlarged 109 anyway, although one of the cheaper 110 kits would be ideal for the u/c nacelles.  Plastic card for the inner wings and the spare wings from a Hobbyboss 109G-10 for the outers.
As for the Me 210.  The real problem stemmed from Willy Messerschmitt's obsession with saving weight.  He ordered a chunk taken out of the fuselage which affected the aerodynamics and stability and there were various fixes to bring it back into line.  Some worked better than others and eventually the section of fuselage went back in and the aircraft got new engines and was rebadged as teh 410 to make people think it was a new aircraft.
Good ideas, but too expensive for my taste. Some parts are missing or habe to be scratched - plan is to keep dimensions as compact as possible. Already have an alternative fuselage front end, biggest concern are the engine nacelles, but there are leftover pieces from the Whirlwind that could be recycled. Also needs a bigger tail - I consider a Me 262 fin!
Offline Gondor
  • What-IF SIG
« Reply #31 on: January 05, 2015, 11:00:17 am »
Received today a couple of ebay wins
1 x 1/72 Maintrack F-107 which I will use with the Trumpeter kit I already have.
1 x 1/72 Quickboost Ju 88G-6 FUG240 "Berlin" Short Nose conversion, probably to be used with an R-1 version.
Offline Martin H
  • Im their Leader. Which way did they go?
  • What-IF SIG
« Reply #32 on: January 05, 2015, 11:37:55 am »
via ebay
 Special hobby Meteor T-7 1/2.
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
IPMS (UK) TSR-2 SIG Member.
IPMS (UK) R & D SIG Member.
IPMS (UK) DC-3/C-47 SIG Member.
Offline DogfighterZen
  • Bmx, music and whif junkie
« Reply #33 on: January 05, 2015, 01:17:39 pm »
What do Hasegawa mean by "special" bombs?
Smart Bombs, the 2nd generation smaller LGBs brought in after Kuwait 91.
Note by set IX the next generation are referred to as Joint Direct Attack Munitions.
I think they are probably referring to AGM-154 JSOWs(JointStandOffWeapons) on set VII as special, like you said, JDAMs are on set IX, although set VII also has some.
« Last Edit: January 05, 2015, 01:19:50 pm by DogfighterZen »
Offline zenrat
« Reply #34 on: January 06, 2015, 02:02:45 am »
So not nukes then (sometimes you see nuclear weapons referred to as Special Bombs).  Thanks.
« Last Edit: January 06, 2015, 02:05:35 am by zenrat »
Offline Thorvic
  • Evil Kit Finder Git General
  • Administrator
    • Album
« Reply #35 on: January 06, 2015, 04:26:53 am »
Nope, if you want Nukes then the Italeri US/NATO set had the US mk-61, The Trumpeter Vigilante has the 28 and 57 (I think !!), but for others try Belcher bits as they do a British set in 72 and a couple of US sets in 48th (could do with those becoming a 72nd set !)
Offline zenrat
« Reply #36 on: January 07, 2015, 03:00:59 am »
Thanks Thorvic.  I'm not looking for nukes.  I just wondered when I saw the set labelled "special bombs".
Offline Howard of Effingham
  • Tried to ask about GARDENING! and now has to live with the shame.
  • What-IF SIG
  • Does like gardening contrary to popular belief
« Reply #37 on: January 07, 2015, 08:29:56 am »
hmm, my first purchases for the year.....
1/35 RoG M48A2 MBT [it has bundeswehr, US Army and IDF markings but that doesn't worry me as its getting wiffed]
1/72 airfix spitfire IX [with the French markings as well as RAF, the former coming in handy for a potential whiff]
1/35 zvezda Russian tank crew [this is a very useful set indeed]
some more of those revell triangular shaped paintbrushes which are also very, very useful.
www.beanstalkcharity.org.uk/
proud member of the following IPMS [UK] SIG's
South Atlantic, What-If? and USAF
also a very proud member of the Handley Page Association
Offline Dizzyfugu
« Reply #38 on: January 08, 2015, 03:22:54 am »
A Hobby Boss Spitfire VB trop.; have an idea for a fictional operator after WWII.
Offline Thorvic
  • Administrator
    • Album
« Reply #39 on: January 08, 2015, 05:07:59 am »
Off eBay the last issue of the original Airfix Lockheed Hercules in standard late 70's RAF colours
Offline JayBee
  • Won't go back to Hull again
  • What-IF SIG
  • "Aquilla non captat muskas"
« Reply #40 on: January 08, 2015, 07:31:25 am »
Just arrived from the Big H
KP Avia S-199 "Messer/Sakin", new tool, superb.
Maestro Decals Saab Safir B/C/D. This includes an example for Air America  :blink:
Brengun Pou-de Ciel 1/144scale, tiny, tiny, tiny.  :blink:
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #41 on: January 08, 2015, 07:46:11 am »
Also from the Big H, three sets of CMK resin P-51 exhausts for the Tri-Stang.
Amazingly you get two different patterns in each set so now I've three spare sets of P-51 exhausts!  :o
Offline kitnut617
« Reply #42 on: January 08, 2015, 09:19:51 am »
What do they look like Kit, I'm looking for the ones that have the fairings around the stubs
Offline PR19_Kit
  • What-IF SIG
« Reply #43 on: January 08, 2015, 10:31:10 am »
One of each set has the fairings, and the other type has just the plain bent pipes, both superbly moulded. I'm using the faired versions for the Tri-Stang, they're the nearest to the P-82B Merlin engine exhausts.
I'm trying vainly to get the Big H page for them but it seems Oulton Broad has left the building.  :banghead:
Offline Dizzyfugu
« Reply #44 on: January 08, 2015, 10:35:26 am »
IIRC, the 1:72 Hobby Boss P-51B, C & D kits also offers two sets of exhaust stubs - with and without the fairings.
