Author Topic: North American P-86B (or a F2J-1 -- depending who gets it)  (Read 15731 times)
Offline kitnut617
Re: North American P-86B (or a F2J-1 -- depending who gets it)
« Reply #30 on: January 08, 2016, 12:31:08 pm »
Thanks Kit,
Well been doing some research, and after looking at the various flap systems, I'll stick with my original plan and go with Fowler Flaps.  It seems there are various ways to mount and operate the system and the B-29 way (which was a Boeing variation of the Fowler flap) has them mounted on tracks so that's the way mine will go.  I think I'll look at one of my Revell/Monogram B-52's as they have actually modelled the flaps to work and the B-29 system is similar.
Offline kitnut617
« Reply #31 on: January 10, 2016, 08:24:45 am »
I've got the wheel bays glued into their new location,
So the next step was to see if it would fit into the fuselages. Starting with one fuselage first I cut a corresponding hole for the wheel bay into it,
then inserted the wheel bay into it,
a problem I could see was it would be too deep into the underside,
I decided to look at the undercarriage I'm going to use, the F-82 parts. I couldn't help but notice that there's a lot of similarities between the FJ-1 leg and the F-82 leg, except for the wheel size. They're practically the same in appearance and length. I've included the nose gear just so I can see how much of a difference there is between the lot,
Offline kitnut617
« Reply #32 on: January 10, 2016, 08:32:05 am »
After a night's sleep pondering what to do with the bay, I decided to modify the bay so it sloped from the outer side of the fuselage, to the center wing side.  I did this by sawing a couple of notches in the wheel bay wall near the wing joint area, then bent it up to an angle that looked about right. I also cut some slots where the u/c hinge would be so I could level out that bit so it was on the same plane as the wing.
Here' you can see what I did,
This shows the difference very well,
and how the wheel bay now looks in the fuselage,
Now onto duplicating everything ---
Offline Captain Canada
« Reply #33 on: January 10, 2016, 09:49:32 am »
Looking good Robert. Nice to see you working ! On models, that is  :thumbsup:
Offline Tophe
    • my what-if models
« Reply #34 on: January 13, 2016, 09:56:02 am »
I agree: I am happy the Twin-Sabre/Fury will be finished... :thumbsup:
Offline kitnut617
« Reply #35 on: January 13, 2016, 12:00:55 pm »
Thanks guys  ----
I was looking at the F-82 cockpits so I can start planning how to install them when I saw they're actually quite plain, and no decals to spruce it up either. I then remember I had a couple of these True Details sets in the stash;
It's for an F-94 really, but it fits in the time period and just what I'm looking for to detail the cockpits.  Just got to carefully cut the tub into two bits though   :-\
I've also decided to use a couple of F-86 nose u/c bays instead of the odd FJ-1 ones, keeps the bay doors more simple too.
« Last Edit: January 13, 2016, 12:04:09 pm by kitnut617 »
« Reply #36 on: January 13, 2016, 01:13:49 pm »
That will defo help dress it up and add realism !
Offline MiB
  • Makes own decals
« Reply #37 on: January 13, 2016, 03:19:44 pm »
Like Star Wars  :lol: :lol: :wub:
Offline kitnut617
« Reply #38 on: February 13, 2016, 01:36:37 pm »
Haven't had a lot of time for model building lately, had to concentrate on getting my security license and other things at work, but I've manage to get my wing modifications done.
In this pic, the top wing is how it would be in flight, the bottom wing would be for take-offs and landings, all slats & flaps extended and I'm going with the Cutting Edge slats on the outer wings and scratch built slat for the center and Fowler flaps all along the trailing edge.  I decided not to go with the drooping ailerons as I can't find any info if they were a technology back in the late 40's/early 50's.
And the decals have been ordered, which will be a variation of these. Just having the serial numbers changed for what I want.
« Last Edit: February 13, 2016, 01:44:45 pm by kitnut617 »
Offline kitnut617
« Reply #39 on: February 15, 2016, 08:57:01 am »
And I've got the cockpit tubs fitted in, just needs a bit of tidying up before it all gets glued in.
Offline kitnut617
« Reply #40 on: February 15, 2016, 11:32:41 am »
Couple of pics of how the slats and flaps look from the wing root ends, top pic is the center section, bottom pic one of the outer wings. You can see I've made the flaps have an airfoil section to them.
Offline kitnut617
« Reply #41 on: February 21, 2016, 12:03:07 pm »
One fuselage is now almost completely assembled, made up some better air intakes and exhaust nozzle out of aluminum tubing.
Here's a trial fit up of the center wing section with radar pod (wanted to see it like that for the first time) and also the starboard wing. The wings are held there by the aluminum tube I'm going to use as a spar. This should line up the two fuselages nicely.
Been doing some research into drooped ailerons, seems no one thinks they're a good idea.  However, reading the chapter about the Supermarine 322 'Dumbo' in the book British Experimental Combat Aircraft of WW II, it says it was equipped with ""slotted ailerons"" after the normal ailerons were ineffective when the slats and flaps were deployed.  Think that answers the question I had whether enhanced ailerons like that were technology back around 1946-49.  Anyway, I'm going to go with slotted ailerons on this one ---
Here's a couple of pics of the 'almost' finished fuselage.
« Last Edit: February 21, 2016, 12:06:44 pm by kitnut617 »
Offline kitnut617
« Reply #42 on: February 21, 2016, 02:19:05 pm »
Change of plan  --- again.  Had a chat with Evan (our resident aero engineer), and he says just to go the way I have it now  -----  :lol:
Offline kitnut617
« Reply #43 on: March 02, 2016, 02:33:49 pm »
Some progress but I went on vacation for a week or so in between.
Got most of the second fuselage assembled, I just need to modify the wing root on it before I think about gluing the lot together.
In this pic, you can see the wing root fairing in it's original length, this is to match the wing's root leading edge extension, but I have removed that so I can use full span slats.
This pic shows the modification done on the other fuselage already.  I carefully cut out half of the wing root, trimmed it to length then repositioned it in the fuselage side. Then added in some card to fill in the hole.  The thin strips of styrene is to replace the material that the razor saw cuts out (if you're wondering)
This pic shows I still have to carefully file out the air intake on the second fuselage, I'm making it a bit bigger in diameter than what the FJ-1 has.
I'm going to make the fin/rudder taller, I've already got a plan to increase the tail-plane area but got thinking about the fin.  Comparing the P-51H fin/rudder with the F-82 fin/rudder and you can see that the F-82 has quite a bit bigger fin. I'm going with the same line of thought with this Twin Fury but I'll just extend the top of the fin.  It will look like the P-51H fin only bigger once I'm done with it.
Lastly, my decals arrived --- now I've no reason why I can't get this project finished  ---- hopefully ---- maybe ---- well ------
Oh! and another thing, the very nice Falcon replacement FJ-1 canopies I'm going to use --- do not fit the Siga FJ-1 at all (heck, even the kit canopies don't fit the kit), I'm having to carefully re-shape the cockpit opening to get them to fit, you can just make out what I've had to do to get them to fit if you look at the starboard fuselage carefully
« Last Edit: March 02, 2016, 02:45:03 pm by kitnut617 »
Offline NARSES2
  • Global Moderator
« Reply #44 on: March 03, 2016, 06:27:24 am »
Coming along nicely
Decals my @r$e!
