avatar_Ed S
MiG 37 "Flathead" Ilmavoimat
Started by Ed S, February 01, 2014, 08:44:12 PM
Superlative work. That is utterly gorgeous.
However I do have to raise one little point, it can not be a Mig-37 as the Mig-37 is the "Ferret". I know because I have the Italeri kit in my stash.  :rolleyes:
Seriously though, fantastic.
Jim
 I don't think NATO gave the Mig 1.44 a designated Mig number, the called it the ' Flatpack'. Unless you are confusing it with the Su-47 forward swept wing demonstrator also known as the Su-37.
Now I thought about a lace-painting technique, but then I didn't see how that particular pattern could be made with it. I guess there may be some kind of random "scrim-net" stuff that I don't know about though...
 - Morpheus in Sandman: A Midsummer Night's Dream, by Neil Gaiman
 - Indiana Jones '
Ed S
Thanks for the comments.
As to how I did the paint job. The basics are a coat of neutral gray on the bottom and a coat of dark ghost gray on the top. It turns out there isn't really much difference between the colors.
To achieve the camo, I used an airbrushing template from Artool. These are laser cut templates in different varieties. I saw these on the clearance rack at Hobby Lobby a couple years ago and thought I might find a use for them. I got the small and large set. This model was done with one of the small templates. They are made of some sort of solvent resistant polymer.
Here is the small set. You can see that I have removed one of the templates from the sheet. This is the one I used on this model.
Here is a close up of the template I used on the Mig.
This picture shows both the large and small templates.
I'm not completely happy with the results. The templates didn't fit in the corners very well as Dizzyfugu pointed out. Next time, I think I will trim the edge of one of the templates or maybe cut a small section from it with a straight edge to put down in the corners.
Ed
Quote from: McColm on August 01, 2014, 01:32:08 PM
No I am not confused (at least not as much as some of us in this forum about "reality"). I am thinking of the Mig-37B Ferret E, which being a contemporary of the F-117,  makes it in the time line well before the Mig 1.44.
Italeri also did this model in 1/48 scale.
