dragonfly & DC-8 (1/350), red : hybrid aircraft/animals e.a.
ericr
Quote from: steelpillow on October 13, 2015, 09:28:57 AM
I guess for takeoff the propellers swivel up to act as lifting rotors for VTOL capability. In the photo they are pivoted down for servicing.
But the big question is - is this it, or is it just the tip of a giant spaceplane poking out of its underground launch silo?
yes indeed, it must be a tilt-rotor structure, like an Osprey : and by the way, here is a civil version, hence whiff !
(with a nice floatplane on the side, too)
steelpillow
Cheers.
Looks like I'll need to hit up the toy store....who doesn't want bits to make a tilt-rotor in their lego stash !
ericr
do you remeber this ?
Quote from: Tophe on July 01, 2015, 10:37:00 AM
sometime ago you had an idea which got into my mind : the Book-Airplane :
www.whatifmodelers.com/index.php/topic,4461.msg676207.html#msg676207
and I liked so much that I had to try it out : using an Airfix Ar196, and a Clairefontaine notebook, cut to the shape of the wings :
it could have been featured in a Tophe-inspired group build!   ;D
I thought it worthwhile to continue the exploration with another, high-wing example, using a Do-27 :
next one might be a delta  :)
steelpillow
Cheers.
ericr
steelpillow
Quote from: ericr on October 16, 2015, 01:35:04 PM
Quote from: steelpillow on October 16, 2015, 11:17:22 AM
Or a Fokker Dr.I Trilogy?
argh, a triplane notebook aircraft! you are challenging me !  :o
You are lucky I didn't suggest a Phillips Multiplane 21-volume encyclopaedia.  ;D
Cheers.
ericr
Quote from: steelpillow on October 17, 2015, 03:37:52 AM
:o :o :o
that would be called "The Universalis" !
ericr
steelpillow
Quote from: ericr on October 17, 2015, 03:54:57 AM
"real" in the sense of 3D, but stil not "realistic" luckily  ;D
[/quote]
More realistic than you think. The Northrop XP-56 "Black Bullet" tailless fighter prototype had split elevons with a folded bellows arrangement sealing the gap in between. They split apart to provide differential drag for turning, in place of a conventional rudder, and were operated by the air blast coming in through a wingtip duct.
Cheers.
ericr
Quote from: steelpillow on October 17, 2015, 05:21:48 AM
astonishing! It feels a bit like I have reinvented something like the wheel!
which is matter to be proud of  ;D
IIRC the Horsa glider had its flaps/dive brakes operated by a similar system. They could only be used once as there was no way to get them back up again.
ericr
and now for something completely different :
I always liked the shape of the 2cv, a bit like that of the Beetle, and thought about equipping it with the wing of a space shuttle ...
I had already tried a 1/43 one with 1/288 boosters, and a 1/16 Beetle with 1/144 Boosters
http://www.whatifmodelers.com/index.php/topic,37003.msg679216.html#msg679216
and here comes the 1/24 2cv with 1/144 shuttle wings and tail, on top of the 747 SCA :
