avatar_ysi_maniac
Bristol Beaufort and Beaufreighter
Started by ysi_maniac, June 01, 2012, 10:48:44 AM
What if Bristol managed to produce a 4 engined heavy bomber based on Beaufort?
The BEAUFORTRESS.
KiwiZac
I want one! But a DAP-built one with P&Ws...
Zac in NZ
https://linktr.ee/zacyates
Unarmed Beaufort ready to perform tasks like liason, medevac, and similar.
Quite a few had the turret removed and the area plated over.
Single seat fighter torpedo bomber Beaufort
Random Whiff idea: how about a Beaufort carrying a what-if early British air-to-surface missile, something like the German Hs 293 or Fritz X or the US Bat or Kazon(?) weapons? It would seem ideal since it has the oddball bomb bay with narrow extensions fore and aft for a semi-recessed torpedo.
I'd go with something with both a higher performance and more ground clearance - Mosquito, Buckingham or perhaps Brigand.  Mosquito was used in trials.
So, due to Airfix's generosity/desperation/overstocking (take your pick), I now have three Beauforts, and only one What-If idea for them. So what should I do with the other two? (Note: "give one to me" is not the answer I'm looking for...).
My idea is a "Super Beaufort" with Beaufighter wings and engines, and a Defiant four-gun turret. It may or may not get some sort of early air-to-surface missile if I can concoct something.
The donor Beaufighter would get the Beaufort wings & engines, and be presented as a very early prototype, possibly with a twin-fin setup.
The donor Defiant would get a single swivel gun, wing guns, Sptifire-style wing-mounted radiator/oil cooler and a dive-bombing crutch on the centreline ( a Divefiant, if you will...). It might also get skis and Finnish markings.
Ooops!  For 'Divefiant' I read 'Deviant'.
As for your 'spare' Beaufort, why not simply turn into a European theatre RAF transport (as the Aussies did) - wartime equivalent/precursor of the post-war Buckingham?
Alternatively, do the wing/engine swap and repurpose the Beaufort as a tactical bomber with 2 Gp in lieu of Venturas?
You could use two to create a four engined bomber, serious bashing. Use the centre fuselage from one as an extension plug and the inner wings and engines to make a four engined wing. Pretty much like Carlos's Beaufortress above.
Quote from: Weaver on September 09, 2025, 08:03:20 AMMy idea is a "Super Beaufort" with Beaufighter wings and engines, and a Defiant four-gun turret. It may or may not get some sort of early air-to-surface missile if I can concoct something.
For a different look, you could use Merlins from a Beaufort II. CMK do a couple of conversions that simply replace the inner wing section, assuming they fit the Beaufort okay.
