avatar_roughneck06
Which is an accurate sized F/A -18????
Started by roughneck06, May 30, 2012, 03:16:15 PM
roughneck06
I have some CAP Aero F/A 18s and some mountford F/A 18s- size difference is very profound- anyone here know which is more accurate? I suspect the mountford ones are correct.
Also- the mountford F/A 18s came in a pack of 3- all 3 of them have a defect- i.e. missing tailfin, missing missile point on wingtips, etc. Not one of them are flawless. Is this just the way things are with this scale or should I send them back for replacement?
famvburg
  Why not check the measurements of the full sized a/c to the models & go from there? Just a little math.
Nick
I've never heard of CAP Aero or Mountford, but Google says these are model ship makers. I assume these models are teeny tiny scale?
If the 3-pack is all so badly moulded I'd look to send it back and demand a good quality set. You might be better asking about the quality on model ship forums as they'd have more experience with these makers.
Also, have you got a set of A/B/C/D Hornets, and one of E/F Super hornets? Because the Superbug is quite a bit bigger than the "Legacy" Hornet. That might account for the size difference. Easiest way to check is the E/F's much larger LERXs and squared, "stealthy" intakes compared to the smaller round ones on the original design.
Quote from: kitbasher on June 03, 2012, 04:11:18 AM
I'd have thought a real one?
(sorry)
Ah yes, buuuuutttttt does it match up with the published plans ?  :wacko: :rolleyes:
Aircav
Quote from: NARSES2 on June 04, 2012, 01:25:02 AM
(sorry)
Who's version of the plans.  ;D
Sir Sydney Camm
Vertical Airscrew SIG Leader
Were the measurements made with Imperial or Metric?
Quote from: rickshaw on June 04, 2012, 01:30:12 AM
As it's US probably that strange mixture of Imperial with metric units they use eg 1 US Ton = 2,000lbs, 1 Imperial = 2,240lbs
Quote from: NARSES2 on June 04, 2012, 01:36:13 AM
No wonder no one pays with Imperials any more!  ;D
It gets worse than that.
My last employer's desigin office, in Minneapolis MN, started to produce what they called 'Universal' fixtures and actuators. These had all the usually un-used bolts and screw threads in US sizes and the bits that the customers bolted their cars to in Metric. In the Service Dept we had to double up on all our tools, and then HQ asked why our margins were smaller that year.............. <sigh>
