The Wooksta!: Not a Spitfire Blog - comments thread.
Started by The Wooksta!, May 01, 2012, 08:35:04 AM
Lost Cosmonauts
Quote from: NARSES2 on March 29, 2024, 07:41:12 AMAnd here's mine
Quote from: Lost Cosmonauts on Yesterday at 05:01:28 AM
Printers are running in Tim's capable hands
Can I ask a rather basic question simply to satisfy my own inquisitiveness ? How long does it take to print a kit like this ?
For a small printer like mine it is split across a few runs
For P1103 you get print 1 a nose, both wings and a tail ~ 10 hours, print 2 a pair of fuselages ~12 hours, print 3 gives 3 sets of small parts ~ 5 hours. Print 4 gives a big batch of cockpits ~ 5 hours. So you are looking per kit maybe 20 cumulative hours of machine time plus water wash, solvent rinse and UV cure on top for all of the parts
Quote from: Lost Cosmonauts on March 31, 2024, 08:01:10 AM
Ah, so the total print time is 20 hours roughly, but while one print is running you can do such things as wash, rinse and cure previous prints.
Lost Cosmonauts
That'd be true if you had multiple spare build plates but as the print is still attached to the build plate for the water/detergent wash and you've got removing it and cleaning the build plate, refitting and levelling to do before you can set it going again. There is more hands on work than you might think
Thankyou, that's interesting.  :thumbsup:
I'd often wondered about it and now I know  ;D
I do like that He 277 Lee, hope you can make some progress  :thumbsup:
It's the engine mounts that will be the issue with the wings.  I've figured out the deeper fuselage and how to do it, but will need to do some digging in a wreckage box.
Willie mentioned that he wanted to try converting a 177 to a 274.  Having looked at both, I'd say it's possible but would need to look at a wing donor.
Like the idea of a Beaufighter TF.X with turret Lee  :thumbsup:
It's one I've been thinking about for years.  May have to resurrect that turret Blenheim as well. It had an accident and has yet to see primer.
One or two of the turret Beaufighter casts didn't come out, air bubbles in the gun mounts.  I'm wondering if I can replace it with a Bristol turret with a pair of 20mm cannons from a Shattipuss.  I've some Aeroclub Shack bits that could be ideal
Four blade props, definitely.  I may use the Firedog rocket mounts - I think they were used on far east Beaus at the very end of the war, as I've seen a photo of a TF.X with said mounts with SNAKE on the rear fuselage.
Stick with the P.1103, Lee - you know it makes sense 👍
They have a nice choice of sanding equipment at B&Q Lee
Quote from: Gondor on April 27, 2024, 01:23:48 PMThey have a nice choice of sanding equipment at B&Q Lee
I have a lot of files and sanding blocks.  Seems to be doing the trick.
The fella that does the Tempest detail set has also done some very nice upgrade sets for Javelins and Canberras. He's a nice guy and I met him at Telford back in November after buying quite a few of his Canberra bits previously.
Was there not a proposed version of the Weslley that was supposed to have the Centaurs as a power plant anyway?
I doubt that the Wellesley could take the power of a Centaurus.  Besides, production had ceased well before the war.  Unless you mean the Warwick, as there were some that used the Centaurus. One did fly with the annular radiator Sabres, as the option to do it is in the Contrail kit.
May well be worth rejoining Britmodeller just to get that dude's details, as his stuff looks really good.
