avatar_kitnut617
Sandringham conversion for the Airfix Sunderland
Started by kitnut617, March 28, 2012, 06:59:09 AM
Hi,
I'm sure there is/was a conversion set to convert a Sunderland into a Sandringham, does anyone know which manufacturer it was that released the set ?
Robert
Martin H
Im not aware of any conversion for a Sandringham.................yet
Id be interested if there is/will be one :)
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Martin H
Im sure your trying to slowly bankrupt me Geoff LOL
Unfortunately,
I was going to suggest Dana Kopher for that.
The Sandinghm conversion is mentioned in the Airliner SIG Forum quite a bit but I've never seen one. Dana's stuff is held in high regard in the US, but it's not cheap.
Martin H
Quote from: PR19_Kit on March 28, 2012, 09:53:43 AM
What else has been done then?
Unfortunately,
Radish
The Queen Mother's arm waved at me at Sandringham :banghead: 1974
Quote from: Martin H on March 28, 2012, 10:35:24 AM
Mostly he does engine conversions of 1/72 scale piston engined stuff, but I can't get into the AMD Group files list at the moment.
May be worth emailing Dana at dkopherATyahoo.com and ask him.
Thanks guys, I've just sent an email to Dana to see what's available
raafif
as there's no Sunderland thread in the whiff files, I'll ask here ...
    Anyone have a clean Sandringham line-drawing ??? (or Sunderland for backdating)
     the one I'd usually start with (on that French/Russian site) is a bit too grubby & would need a fair bit of work to make it suitable for colouring (have an idea for an airline ... the name is secret for now :wacko:).
thanks raafif
This any help?
http://www.f-rsin.com/pages/collection/14025-26-27.html
Side views of the 1/144th resin kit.
Sunderland drawing on Wiki but it is pretty small.
Looks like a larger image on Blueprints but you have to register to see it.
http://www.the-blueprints.com/blueprints/modernplanes/modern-sa-st/18677/view/short_sunderland/
US SIG Leader
Something wrong with that drawing......  :unsure:
The engines on a Sunderland point outwards, not quite at 90 deg to leading edge, but getting there. Shorts had to sweep the wing back a bit after they built the prototype to solve a CG issue IIRC, but left the engines as they were.
It's a Mk I too, with the unfaired step and the twin upper fuselage gun positions. By the time they were being 'civvie-ised' most had the faired step and upper turret.
[JMN mode off]
raafif
Quote from: philp on March 28, 2012, 10:40:00 PM
This any help?
thanks Philip,
                 heres what I've done ...
That bottom one's tricky, a military Sunderland converted to a civvie Sandringham and then re-militarised!
I like the side mounted barbettes, are they to give some means of protection to the rear without fitting a tail turret again?
