My stash just grew again (2012).
Started by Martin H, December 31, 2011, 04:24:19 PM
Quote from: Weaver on August 25, 2012, 07:02:04 AM
Quote from: Gondor on August 25, 2012, 06:28:27 AM
1 x 1/72 Submarine Swift fuel tank
Is that going to be a model of one that's crashed in the sea then?  ;D
I should have sean that one coming.
Should have been Supermarine Swift
From Ebay, a SKY Models sheet (72-060) containing markings for lotsa Fw190Ds/Ta152s. 33 machines in all! Good value at about £6.
Nick
Quote from: JayBee on August 25, 2012, 09:19:50 AM
I got the Italeri, 1/72 scale MQ-9 Reaper kit.
However when I got home and had a look at the contents it was the 1/48 scale kit. The box said 1/72, the instruction sheet said 1/72, and the transfer sheet is 1/72, but the plastic shure as He11 is not.
I gave the shop a phone call and there is no problems there.
So all I am saying is if you are buying this Italeri kit, check it before you pay.
Jim
Italeri don't do a 1/48 MQ-9 Reaper (if they do, it's not visible online). You do realise it's a rather big aircraft?
36ft long, 66ft wingspan which I guess to be 6 inches by 11 inches in 1/72 scale.
Ah, but Kinetic do, and Italeri have reboxed several Kinetic kits.
Martin H
if you can find it, get the Skunkworks boxing of the kit. For the same price as the Italeri boxing you get two kits instead.
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
and now I must eat humble pie, as having checked the measurements Nick is correct and the kit is definitely 1/72 scale.
I just did not realise just how much larger the Reaper (Predator B) was than the Predator A. :rolleyes:
Martin H
Unfortunately,
Just got back from the Middelkerke Modelshow, and got a limited stash addition (trying to cut back and reduce)
-Tamiya 1/72 J7W1 Shinden
-Airfix 1/72 Douglas Skyraider (both for my '46 theme build)
-Revell 1/144 Supermarine Spitfire Mk.1
Aircav
Sir Sydney Camm
Vertical Airscrew SIG Leader
Quote from: Martin H on August 26, 2012, 08:31:11 AM
;D hows the pie tasting Jim?  :thumbsup:
Mmmmn, Pie!
Was tempted by some Scotch pies from Morrisons when I did my shopping earlier (but forgot the Weetabix - d'oh!) and had one for lunch.  Wished I hadn't.  Bland and tasteless.
Aircav
Quote from: The Wooksta! on August 26, 2012, 11:27:49 AM
Mmmmn, Pie!
Theres a very good pie shop in Whitby.  ;)
Sir Sydney Camm
Mmmmn, Pie!
Realy Lee, what do you expect buying from an english supermarket. You surely do not think that the best would be exported South of the border.  :wacko:
Quote from: JayBee on August 26, 2012, 02:31:38 PM
OK what's a Scotch pie....meat, potatoe ? Hot, Cold ?
Can't beat a really good steak and kidney pie from "Piemaster" although their lamb one is very good. Favourite pork pies are from the "Pie Man" in Borough Market...superb  :bow: :wub:
Any way back on subject. Added another Airfix Spitfire 22 to the stash, it looked all forlorn and lonely sitting there on the shelf  :-X
I'm going to see if I can use some of the spare bits from the Special Hobby F21 on the Airfix 22 - mainly that sting section of the rudder and the contraprop.
Given that the fit of the F21 seems lightyears better than the vile Xtrakit F22, I may have to get one or two more - if only for the spares.  It's also made me think about having another bash at the Xtrakit 22 - there's a set of short cannon barrels for the F24/FR47 so I may try to do one as an F24 instead.
Quote from: The Wooksta! on August 27, 2012, 01:26:24 AM
The Special Hobby Spitfire f24 and Seafire 45 are due next from them
