avatar_Radish
Airfix
Quote from: Weaver on July 05, 2025, 09:52:55 AMOooh, this is interesting: Airfix have just put a video up on Youtube doing a walkaround of an Avro Lincoln at the RAF Museum. Now why would they do that, unless they were, at least, gauging interest in a kit, or maybe even because they were there to laser-scan it and what to pre-hype the announcement? Assuming that's the case, I've left them a very encouraging comment, and it wouldn't hurt if other people did the same (hint, hint...). :thumbsup:  :thumbsup:  :thumbsup:
They could have at least spelled "Lincoln" correctly in the thumbnail. :banghead:  :wacko:
About time too!  :-\
And of course it has longer wings...........  ;)
It would be nice, but then I would have to come up with something else to do with the Blackbird conversion set I have  :-\
Quote from: Gondor on July 05, 2025, 10:47:02 AMIt would be nice, but then I would have to come up with something else to do with the Blackbird conversion set I have  :-\
Thank you for your sacrifice - buying that probably made Airfix do it... :wacko:  :wacko:  :wacko:
Martin H
Ditto that.
Plus i also have the DB lincoln set from ebay several years back.
Wouldnt stop me buying a full kit should it become available.
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
I'd be very tempted.
Don't have possible references immediately to hand, so can anyone cast any light on Lancaster, York and Shackleton fuselage widths, please?
Lancaster 5' 9"
York 10' 6"
Shackleton 7' 4"
Quote from: Gondor on July 05, 2025, 01:06:11 PMLancaster 5' 9"
York 10' 6"
Shackleton 7' 4"
Cheers 👍
Quote from: kitbasher on July 05, 2025, 01:10:45 PM
York 10' 6"
Shackleton 7' 4"
Cheers 👍
Your welcome, although Google was my friend for that.
How hard would it be for them to make the nose separate and include plugs to enable building a B.II or a Mk.30A or a Mk.31?
So there's hope of them providing the Avro Shackleton MR.1 if they produce the Lincoln?
Quote from: McColm on July 06, 2025, 11:29:58 AMSo there's hope of them providing the Avro Shackleton MR.1 if they produce the Lincoln?
No. The Shackleton MR.1 has a completely different fuselage to a Lincoln. The engine pods and fronts are different as well. In fact, the only common things between the Lincoln and Shacklton MR.1 were basically the wings, mid-upper turret and tail turret, at least on the prototype.
Quote from: Gondor on July 06, 2025, 01:17:06 PM
Airfix has done the MR.2 and AEW.2 so the MR.1 would mean changing the nose, engines and rear tail. The radar moved to under the nose as well although this might be an easier option for the Revell AEW.2 as the nose is a separate part to the rest of the fuselage.
Quote from: McColm on July 06, 2025, 10:48:58 PM
No, your wrong about the engines. You asked about getting a Shackleton MR.1 from a Lincoln. The engines were the same for all the Shackleton's, the nasals are different between the Lincoln and all Shackleton's.
Yes, the nose and tail would have to be changed but No, the radar was a different radar so you can't use the one in the AEW kit if you want to do a real MR.1
There was a conversion set that was produced by Ally Cat, so they are out of production I believe.
Beermonster58
Surely the name of the RAF's most overlooked bomber is spelt M A N C H E S T E R?
