A Model
Started by Green Dragon, February 18, 2009, 05:12:25 AM
IIRC, the u/c was fixed in the down position.  Mind, I'd like to see that wing fitted to a 109K fuselage or the Revell G-10 could be easily converted.
The real thing - Me-109 V31 with belly radiator and wide undercarriage:
regards,
Quote from: Maverick on November 07, 2010, 04:33:49 PM
I also notice that Amodel are releasing a Yak-141 'Freestyle' in 72nd.
Mav
Sure you don't mean Art-Model which are a different company who also produced the Injection Moulded Yak-36 Freehand ?
Maverick
My bad, i was at on an online shop looking at the 109 in detail and saw the Yak & thought they were the same manufactuer.
famvburg
      Wouldn't that be INWARD retraction?
I notice it was a test airframe for the Me-309's undercart config, hence the outward retraction.
Mav
Maverick
My bad again, I'm blaming the cold I have, lol
Vis a vis the recent postings about the forthcoming A Model Bristol Brabazon, OGL and I were strolling around the stands at the MK Show today, as you do, and came across Ken Duffy on the Soviet Air Force SIG. He showed us his review copy of the A Model Brabazaon, and is it ever HUGE!
The fuselage is a pre-bonded fibreglass moulding, already joined so you can't add all the seating if you wanted to (as if.....) and the wings, also fibreglass, have injection moulded inserts to take the engines and props etc. You actually get all eight of the engines to show through the hatches if you want to!
The piccie shows the size of it, darned if I have a shelf that big, but I wish I did!
So, then, no Met Flight Brabazon?  No Maritime Patrol Brabazon then?  ;)
Quote from: rickshaw on February 06, 2011, 04:11:19 PM
Surely he's not going to resist a high-altitude PR Brabazon with extended wings and B-36-style booster jets.... ;)
Quote from: Weaver on February 06, 2011, 06:38:41 PM
Ah, the magic formula!  Extended wing-tips, perhaps with Proteas turboprops replacing the Centaurus piston engines?  Will that be the right bait?   :lol:
I've got plans for three.  BOAC Speedbird, Queen's Flight & use the wing of the third to create one of the Bristol 100 ton bomber projects.  Just need to find the money to buy them, the skill & time to build them & the barn to display them in! :blink:
Isn't there a vacform kit from the States?  That'd be easier to build.  Storage would still be a problem!
F-RSIN do a 1/144 Brabazon...
Quote from: The Wooksta! on February 14, 2011, 03:19:46 AM
Yes indeed, kitnut617 has mentioned it more than once, and I can't remember the maker of course!  :banghead:
Execuform or Combat Wings?  It was some micey outfit I'd barely heard of.  IIRC, they were doing a Saro Princess too.
http://www.whatifmodelers.com/index.php/topic,26801.0/highlight,brabazon.html
