avatar_GTX
Gloster Gladiator whiffs
Started by GTX, July 04, 2008, 03:19:36 PM
BUMP
ive recently got my hands on an extra Gloster Gladiator Mk.I, and i had this dream recently, wher i saw one in USAAC Blue/yellow colors. ive been roughing a profile on it and i couldnt believe how good it loks in that color scheme.  :wub:
im definatly going to make a model of this  :mellow:
also, ive been playing arround with the idea of a RR merlin powered variant.  :mellow:
Quote from: Nils on October 18, 2020, 01:13:58 AM
Ah, that would be the rare wingless Gladiator, then! ;D
I transplanted a Peregrine with a belly radiator onto a Gladiator airframe some time ago - worked well and (still) looks good.
1:72 Gloster Glaive Mk. I, "Δ 183" of the Hellenic Air Force's 22 Mira Dioxeos, Ioannina (Epirus region), March 1941 (Whif/Kitbashing)
by dizzyfugu, on Flickr
Not certain about a bigger/heavier Merlin, though.
BUMP
That would be good to see Nils  :thumbsup:
Idea for a Gladiator wif that I've toyed with occasionally is for a parasol winged version. Don't know if you could simply get away with removing the lower wing or you'd have to do more extensive work to the upper one though ?
Surely it would have to be either larger or more efficient in order to generate the same amount of lift?
Quote from: zenrat on October 19, 2020, 04:17:48 AM
That's why whenever I've thought about it, it's only been for a second or two. I suppose I could compare the upper wing in the Airfix kit to the parasol wing from one of the PZL's in the stash ?
Nils - a few years ago I posted up a Kestrel Gladiator III (can't find the link yet!), using the front end of Ye Olde Airfix Defiant, so I guess it was sort of a Merlin Gladiator.
For quite some time I have been thinking of a floatplane Gladiator.
Single/Central float with  small outriggers.
Finnish airforce.
All I need is a suitable donnor for the floats!  :rolleyes:
Replace the Mercury with a Pegasus (or if you want to go wild, a Hercules)!!
Quote from: Rheged on October 19, 2020, 11:28:39 AM
Nah! Go REALLY wild and bolt a Centaurus on there.  :thumbsup:
Quote from: PR19_Kit on October 19, 2020, 11:38:44 AM
Or a Python off a Wyvern!
The Farley Fairy Penguin had a Hercules.
While the Hercules has twice the power of the Mercury it also had twice the weight so there are CoG issues to address.
Quote from: kitbasher on October 19, 2020, 11:04:51 AM
Found it.  One of my favourites.
https://www.whatifmodellers.com/index.php?topic=33914.0
I've sometimes wondered about using a Gladiator as the basis for a monoplane similar to the F5/34.
Quote from: JayBee on October 19, 2020, 11:23:03 AM
Finnish airforce.
I like that idea. Something Japanese would probably work as the float donator ?
Quote from: NARSES2 on October 19, 2020, 06:20:52 AM
Sesquiplane or Bellanca Aircruiser 'flying-strut' style?
