avatar_Daryl J.
Saab Draken WHIF Ideas
Started by Daryl J., December 10, 2007, 01:16:40 PM
perttime
Quote from: thundereagle1997 on August 26, 2023, 03:24:03 AMWould a Draken be able to have a 360 degree bubble canopy with a cut down fuselage & twin vertical tails & canard foreplanes?
I don't think you can cut down the fuselage behind the cockpit. I suppose you could raise the cockpit or make a completely new forward fuselage.
Twin tails at the break in the double delta might work
Canards in the nose would surely disturb airflow into the intakes. Perhaps somewhere on the inner section of the delta wing?
Jesse220
Why not make an unmanned variant of the Drakken?
Snowtrooper
Quote from: perttime on August 26, 2023, 03:59:49 AM
One of the proposals (35 MOD NivÄ 4) for an updated Draken did include minuscule retractable canards - vortex generators really - in the intake sides.
Booble canopy for 1 or 2 seats Draken
Looks a lot better than standard!  :thumbsup:
Two-seat Drakens had small ventral fins at mid-wing:
Something similar (maybe a little larger) could be used to allow a deeped single-seat forward fuselage with a bubble canopy, something akin ot the F-11 Tiger forward fuselage.
Beermonster58
https://youtu.be/HbjiQ7vvQH0?si=pJTXBt4oEn_HdBrc
I have GOT to have one of those!! ;D . Although the "real" aeroplane was launched from a ramp, I'm assuming it would have a conventional undercarriage for landing so, once I get a suitable kit, that's how I will proceed.
perttime
Quote from: Beermonster58 on October 10, 2023, 04:09:57 AMhttps://youtu.be/HbjiQ7vvQH0?si=pJTXBt4oEn_HdBrc
Hmmm... a Thunderbirds Draken  :thumbsup:
Beermonster58
Quote from: perttime on October 10, 2023, 04:18:30 AM
Looks good, doesn't it ;D
Quote from: Beermonster58 on October 10, 2023, 08:41:32 PM
A set of Lindburg 1/128 scale engines and your in!!
Quote from: Weaver on October 09, 2023, 11:11:47 PMTwo-seat Drakens had small ventral fins at mid-wing:
Not the Danish TF-35's. I haven't been able to find out why, though, as both Swedish and Finnish trainer Drakens did.
mat
Quote from: Pellson on October 11, 2023, 05:24:49 AM
The small ventral mid wing fins were added for stability. The danish TF-35s had the long rear fuselage, which gave the necessary stability needed for a trainer front. So no mid wing fins on the danish TF-35.
Quote from: mat on September 09, 2025, 04:39:04 AM
Also, it seems the load pylons provided some extra stability, and those were almost always fitted to the TF-35. That's the route I'm taking with my Sk35, btw. ;)
So the combination of ventral fins and a long rear fuselage might give you enough side area for a raised cockpit area, suitable for a stepped-seat trainer or a fighter with a bubble canopy and a bigger radar.
Quote from: Weaver on September 09, 2025, 06:28:21 AM
Well - almost. A bigger radar was tested in a wind tunnel, and found to severely deteriorate not only the longitudinal stability, but also the so called zero resistance, or, as we say in automotive the Cw-value. The twoseater canopy did not, it only affected the longitudinal stability somewhat, and one should remember that the Swedish and Finnish Draken trainers flew a lot without these ventral fins as well. They were prefered as they improved the stall exit characteristics, but the aircraft was still more stable without them than any Starfighter was. Especially in the transsonic regime.
