avatar_simmie
Ju-87 Stuka
Started by simmie, December 05, 2007, 06:45:42 AM
Quote from: RAFF-35 on November 23, 2025, 01:02:43 AMRegarding the Stuka's dive brakes, could they be moved to above the wing or fuselage mounted (skyraider style) to make room for more under wing stores but retain the dive bombing capability?
Just spitballing here but if they were above the wing could they affect lift if they slowed the airflow over the top of the wing?
Only where the attachment brackets were.
RAFF-35
Quote from: zenrat on November 23, 2025, 03:14:17 AM
Potentially,  that's kinda the issue I was thinking of but wasn't sure if it would or not. Fuselage air brakes it is then 🤔
The A-36 Apache had top-of and bottom-of wing mounted dive brakes, but they were recessed.
Quote from: Rick Lowe on November 23, 2025, 08:43:47 PMThe A-36 Apache had top-of and bottom-of wing mounted dive brakes, but they were recessed.
Yes, the bottom ones pivot fwd, the top ones pivot aft. They stand away from the wing enough that the top set don't act as spoilers. It was a neat design that worked very well.
The "they were wired shut in action" story is evidently as much of a myth as the name Apache. It was the A-36A Mustang
I suppose something similar could be done on the Stuka, where they'd
be placed is the question. The top set would need to be recessed when not deployed, that's not as critical on the bottom aside from considerations in terms of drag. They'd definitely need to be slotted like the A-36A or perforated.
