avatar_P1127
Supermarine Swift and Attacker
Started by P1127, November 30, 2004, 08:39:00 AM
That does look VERY good, very Campbell-Breedlove-Arfons inspired.
Go on H, build it!  :thumbsup:
Hmm - the artist has done some prettyfication work on the nose, making it longer and less upswept than on the real thing. Having looked at the kit fuselage, it's a good deal less elegant without a good deal of work.
Quote from: Weaver on February 04, 2018, 08:43:24 PM
F7 nose conversion?
I tghought so, too, when I saw the artwork - the fuselage looks pretty slimmed-down (or is it the lowered canopy?), the real thing is rather bulky. Nevertheless, a very nice concept. And another confirmation that we might need a Racing! GB in the future.  ;)
The aircraft planned for the conversion was FR.5 WK277
http://www.rafjever.org/2sqnpic024.htm
WK277 is the Swift in the Newark Air Museum.
Looking at the drawing and Swift images, what about flipping the nose 180 around the centreline?
Quote from: joncarrfarrelly on February 05, 2018, 12:42:57 AM
You can't do that, silly!  The nosewheel would be pointing straight up!  That'd be no use at all, unless you were landing upside down!   ;D ;D
Quote from: rickshaw on February 05, 2018, 05:34:26 PM
Are you related to my eldest daughter?
She once built an early Airfix Spitfire IX (In fetching shades of green, blue and pink...) but with the wings swapped over so that the wheels pointed UP alongside the cockpit.
I suggested that it'd work better with them on the bottom to which she replied, with a VERY scornful look 'But how would the pilot KNOW they if they were up or down if he couldn't see them Daddy???'  ;D ;D
The obvious pragmatic solution is to have wheels on the top AND the bottom so it doesn't matter which way up you are when you land. Simples!  :thumbsup:
The discussion of upside-down undercarriage has inspired me to recreate my Very Bad Ideas thread here:
http://www.whatifmodellers.com/index.php/topic,44868.new.html#new
Enjoy.... :wacko:
I have issues with the look of the Swift.
Specifically the nose and the rudder.
AndrewJ has vastly improved the look of the nose with his F7N (http://www.whatifmodellers.com/index.php/topic,45238.msg809471.html#msg809471) but IMO either the rudder needs lengthening or the fin needs moving backwards.
I have done a highly detailed technical drawing showing my ideas.  The belly tank would also be left off and so should be ignored.
Swift Calender Sketch by Fred Maillardet, on Flickr
Nice concept!  :thumbsup:
Some area-ruling to the fuselage would be cool, too, but that's probably too complicated to realize.
Area-rule improvement using the same add-on method tested on a Canadair CL-13 Sabre, perhaps?
The leading edge wing-body fairing used on the 545 developed from the Swift would also help.
What was the end result of that test Jon ?
Quote from: Dizzyfugu on May 18, 2018, 03:13:09 AM
See the revised Swift design that never flew, the Type 545.
Quote from: kitnut617 on May 19, 2018, 01:53:03 PM
No improvement in performance, returned to standard config.
