avatar_Spey_Phantom
Seen Over Your House Today
This is getting boring! ANOTHER  A400M, low enough  this time for me to clearly read that it was  ZM 420
Whilst cycling into work this morning I was strafed by saw a low (100 ft ish) flying inline piston engined (i'm not good enough to tell a merlin by sound alone) low wing monoplane over Mornington.  Horizontal stabs were half way up the rudder and it had a pointed nose with no chin or under fuselage radiator.
I didn't see the shape of the wings but i'm thinking Spitfire.  Possibly.
AFAIK there are no Spits permanently living at Tyabb but there is a big warbird presence there and it could have been a visitor.
I hoped you dived into the nearest appropriate ditch  ;)
Quote from: NARSES2 on May 03, 2025, 05:20:05 AMI hoped you dived into the nearest appropriate ditch  ;)
I dodged behind a tree and it was distracted by all the German SUVs.
Quote from: zenrat on May 03, 2025, 05:05:15 AMWhilst cycling into work this morning I was strafed by saw a low (100 ft ish) flying inline piston engined (i'm not good enough to tell a merlin by sound alone) low wing monoplane over Mornington.  Horizontal stabs were half way up the rudder and it had a pointed nose with no chin or under fuselage radiator.
A Spitfire's tailplanes are mid-fuselage height, not half way up the fin. I'm struggling to think of a piston engined aircraft that has such a tail.
Quote from: PR19_Kit on May 03, 2025, 05:32:44 AM
That's what I meant.  Half way up the distance from the bottom of the fuselage to the top of the fin.  ie not at the bottom or a T tail.
Half way up the rudder if you like.
Approximately, and from a fleeting glance as it flew away from me and disappeared behind some houses.
And it was yesterday at 11:45.  I drove in today.
If it had twin under wing radiators it sounds like it could have been a Spitfire in that case.
Early Spitfires only had one radiator on the starboard side, and a small tubular oil cooler under the port wing, but those early ones are pretty thin on the ground.
Oh, and in the air too of course.  ;D
Quote from: zenrat on May 03, 2025, 05:27:18 AM
 ;D  ;D
Quote from: PR19_Kit on May 03, 2025, 08:49:11 AMIf it had twin under wing radiators it sounds like it could have been a Spitfire in that case.
I do know what Spitfires look like Kit.  I didn't get a good enough view to be sure though.
Quote from: zenrat on May 04, 2025, 05:16:38 AMI do know what Spitfires look like Kit.  I didn't get a good enough view to be sure though.
 ;D  ;D
The darn things are always going somewhere too, and won't hang around for us to make a positive ID, ratbags.
Quote from: PR19_Kit on May 04, 2025, 05:30:40 AM
 ;D  ;D
Too right.  And it was two streets over.
Yesterday over West Worthing beach heading east.  Nothing seen on FlightRadar24 so couldn't identify which Spitfire it was but it turned inland shortly after, appeared to route just to the north of Goring and Ferring and then head off west, perhaps to Goodwood.  There's a pair based there so probably one of those.
  You cannot view this attachment.  You cannot view this attachment.
Quote from: kitbasher on May 05, 2025, 02:53:57 AMYesterday over West Worthing beach heading east.  Nothing seen on FlightRadar24 so couldn't identify which Spitfire it was but it turned inland shortly after, appeared to route just to the north of Goring and Ferring and then head off west, perhaps to Goodwood.  There's a pair based there so probably one of those.
  {attach id=87440]IMG_3159AA.jpg[/attach} {attach id=87442]IMG_3159AB.jpg[/attach}
And again! 3rd time!  :-\
Nope, nothing showing here, yet.  :-\
Hope it wasn't the one that crashed near West Hythe yesterday  :-\
