Author Topic: F-4 (F4H-1)(F-110) Phantom  (Read 85213 times)
0 Members and 2 Guests are viewing this topic.
Offline Martin H
  • Im their Leader. Which way did they go?
  • Administrator
Re: F-4 (F4H-1)(F-110) Phantom
« Reply #270 on: August 14, 2020, 11:43:41 am »
This would be another credible alternative scheme for the Airfix F-4K/M...
Might look a little like this then......................
Did this one Ages ago using a Matchbox toom with the scheme and decals taken from am Italeri F-4S kit
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
IPMS (UK) TSR-2 SIG Member.
IPMS (UK) R & D SIG Member.
IPMS (UK) DC-3/C-47 SIG Member.
Offline Weaver
  • What-IF SIG
« Reply #271 on: August 14, 2020, 11:46:59 am »
Nice one Martin - I felt sure somebody wuold have done it at some point. :thumbsup:
Neophyte: Is Eris true?
Neo: Even false things?
Neo: How can that be?
Principia Discordia
Twitter: @hws5mp
Offline McColm
« Reply #272 on: August 18, 2020, 12:45:10 pm »
Good  job  :thumbsup:
Offline tahsin
  • Makes own decals
« Reply #273 on: January 28, 2021, 06:51:38 am »
Apparently a school project? Though it could be a basis for a larger plane. Twin Gast cannon under the nose, four Amraam sized but Sidewinder fronted missiles... 450 gallon tanks under the wings even if they would be rare and everybody would go 600 gallons. Twin 600 under the fuselage? Possibly longer at least by a Sparrow length, so that if you were compare it with a regular Phantom all the missiles would fit within the length of the wing. Would 1/48 fit as a 1/72 though l assume quite a strip would have to be cut across the whole length and a substantial part of the 1/48 canopy painted over to resemble the fuselage?
« Last Edit: January 28, 2021, 06:54:26 am by tahsin »
Online Old Wombat
« Reply #274 on: January 30, 2021, 01:20:37 am »
A Phat Phantom? :unsure:
Offline Pellson
  • Targeted for assassination by JMNs
« Reply #275 on: May 21, 2021, 04:10:40 pm »
Thread archaeology. Always interesting, and in this case, it caused me to wonder one thing.
These Israeli Super Phantoms - to my untrained eye, the air inlets doesnít seem to be very modified at all for the PW1120 engines. Is that really so? I would have thought they would have needed to cope with a somewhat larger airflow.
Anyone know anything?
The two Super Phantoms are shown below - the lower is the Israeli one:
In addition, here are some photos of the IAI Super Phantom from Le Bourget '87:
Also, here are some photos from the Israeli Air Force Museum showing the exhaust of a PW1120 (from the Lavi which planned to use the same engine):
Offline PR19_Kit
  • Closeted Take That fan
  • What-IF SIG
  • Whiffing since the 70s
« Reply #276 on: May 21, 2021, 04:57:50 pm »
Somewhere in the chaos of my house I have a book all about IDF Phantoms, and it has a whole article just about the Super Phantom 2000 in it.
I'll see if I can find it tomorrow.
Offline Pellson
« Reply #277 on: May 21, 2021, 05:04:15 pm »
Thanks. Much appreciated.
Offline Gondor
  • What-IF SIG
« Reply #278 on: May 22, 2021, 01:35:15 am »
Nice images of the Super Phantom. Especially nice to see how the nosels fit the existing fuselage, drawings will only show you so much.
Offline Martin H
  • Administrator
« Reply #279 on: May 22, 2021, 02:41:53 am »
I did the Boeing super Toom upgrade last year. for the JASDF.
A single PW1120 was test fitted and flown in the Kurnas 2000 prototype and worked as well as expected. The only reason the engine swap was dropped was purely down to cost savings. The engine has a slightly smaller diameter than the originals so minimal modification was required.
Unfortunately,
Offline Pellson
« Reply #280 on: May 22, 2021, 04:37:47 am »
Yeah, a quick thought was actually to cheat and use the existing long J79 nozzles with some minor mods as stand-ins for the PW1120. If I just spin that nozzle carefully in a drill, grinding the feather edges a little bit, and then introduces a line at the end of the grinding, I think I would be good, actually. Or, as my models without exception are in flying condition, even just make that line and let them pose as fully open.
I have that F-4F in the lovely Norm 81 camo in my queue, you know..   ;)
Offline Pellson
« Reply #281 on: May 22, 2021, 04:40:23 am »
Afaik, IAI even flew the prototype with two PW1120s. Thatís what I can read from the admittedly few and not so thorough Israeli sites Iíve been able to google out.
Weíll see what Kitíll find in his library.
Martin: I assume you didnít change the inlets at all? How did you do your nozzles?
Offline Martin H
  • Administrator
« Reply #282 on: May 22, 2021, 07:25:29 am »
No change to the intakes. The burner cans are from an Aries F-18 resin set I aquired for that build
None of the refs I have said anything about a pair of 1120's being flown. But I'll be happy to be shown otherwise.
« Last Edit: May 22, 2021, 07:29:17 am by Martin H »
Unfortunately,
Offline Pellson
« Reply #283 on: May 22, 2021, 07:50:15 am »
Hereís one example. I have found a few texts very much saying the same as this, but in all fairness, I do find it a bit hard to verify the reliability of the info.
ďLater in July 986, as IAI proceeded with development of the Lavi, it modified F-4E Phantom #336 to serve as test-bed, replacing its starboard J79 engine with a PW1120ópossibly with assistance from Boeing. Less then a year later, the port engine was replaced as well, and the fully re-engined Phantom made its first flight on April 27, 1987.Ē
Link: https://nationalinterest.org/blog/buzz/1980s-israel-developed-heavy-hammer-f-4-super-phantom-what-happened-44702
Offline PR19_Kit
  • What-IF SIG
« Reply #284 on: May 22, 2021, 09:18:52 am »
I've looked and looked but I can't find that blasted book ANYWHERE!  So sorry.   :banghead:
I got it specifically because it has lots of info on the three IDF F-4E(S) recce birds, the ones with the HUGE nose camera housings, but the book actually covers all F-4s in Israeli service.
