avatar_Archibald
Hawker-Siddeley HS-681
Started by Archibald, September 26, 2006, 11:25:59 AM
Iranian F-14A
Nice profiles,hope you don't mind if I throw a couple of mine up as well.You did a good job on the RAF models,so i did a couple exports.Heres a Canadian SAR model.
Kingston C.Mk1K Tanker Transport-South Africa
If you want a vision of the future, imagine a boot stamping on a human face forever-1984
Current projects:
BAe EAP
OH-58F Kiowa Warrior
S-70C Civilian Hawk
HAL Light Combat Helicopter
S-64 Skycrane Firefighter
Archibald
and why not an AEW HS-681 with a lower tail and a radome on top of the tail (a la Iraqi An-74 AEW) ?
^_^
"An apple a day, keeps the doctor away" (proverb) "If you aim well !"  (Winston Churchill).
Quoteand why not an AEW HS-681 with a lower tail and a radome on top of the tail (a la Iraqi An-74 AEW) ?
Or alternatively bulged nose & tail radomes like the abortive Nimrod AEW:
Archibald
QuoteNice profiles,hope you don't mind if I throw a couple of mine up as well.You did a good job on the RAF models,so i did a couple exports.Heres a Canadian SAR model.
Good work F-14!  I especially like the SAF version, it just looks right in those colours.  You'd need some good sunglasses when stood around the Canadian aircraft!
Simon.
Quotenice profiles Mossie, must try to figure out how to kitbash one in 1/144...
Think I've worked out the best aircraft to use, the Kawasaki C-1 is as close as you'll get.  Looks & dimensions are similar to the early HS.681, you'd need to extend & straighten the wing, find four suitable engines, change the tail & the nose profile.  That's just for starters, there'd me more work to do depending on how close you wanted to get.  It'd be more work to do the later version 681.
BUT (there's always a but), getting hold of a kit of a C-1 probably won't be too easy.  The only one I know of is the Hasegawa kit & at 1/200 it's an odd scale.  It's not easy to get hold of outside the US or Japan either.  So you can do it, but getting the donor kit is the main thing.  Here's hoping Thorvic has one to offer soon!
A three view and a few shots for comparison
Kawasaki C-1
HS.681
Archibald
Just a tought, in the STOL mode can a HS-681 land on a 260 m carrier (Clemenceau, Ark Royal, Essex... ?)
Could be cool to have it as a COD aircraft (hey, the Hercules did it on the Forrestal)
Geoff_B
Heres the completed Aldershot C1 (HS-681) as displayed at Telford alongside the BAC (TSR2) Eagle GR1 and Hawker (P1154) Harrier FGR-1.
