avatar_chrisonord
scribing/adding non existent panel lines.
Started by chrisonord, August 26, 2024, 12:38:05 PM
Light pressure with the pencil, or you'll go through a lot of lead... .5 mill is quite delicate. Voice of Experience... ;)
Quote from: Rick Lowe on August 27, 2024, 10:52:56 PMLight pressure with the pencil, or you'll go through a lot of lead... .5 mill is quite delicate. Voice of Experience... ;)
Thankyou Rick  I have ordered a new pencil, and by the time it arrives, I should have fettled the badly fitting canopy that defies superglue :banghead:
I have quite a collection of various size mechanical pencils from the days when I did engineering drawings.
No leads for any of them though...
I must admit i've never tried drawing on panel lines.  I may give it a go on the Tophstang as while i've sanded the wings smooth the fuselage retains all its original recessed panel lines.
Quote from: zenrat on August 28, 2024, 03:45:19 AMI have quite a collection of various size mechanical pencils from the days when I did engineering drawings.
This project, the PM Nesher has been teetering on the edge of the bin several times, and I should really be better spending my time on other things. Detail is almost non existent, but you can sort of tell its a mirage iii....ish. If you ever get offered one, never speak to that person again.
Andrew Gorman
Dymo label tape is my favorite scribing guide  in the US- much more rigid than heavy duty electrical tape, but also not flexible across the face.
https://www.dymo.co.uk/labels-tapes/embossing-tapes/
Quote from: Andrew Gorman on August 28, 2024, 06:26:18 PMDymo label tape is my favorite scribing guide  in the US- much more rigid than heavy duty electrical tape, but also not flexible across the face.
Mate we all use the Dymo tape and yep it's the business when scribing but s waste when using a pencil...I use electrical tape for this cause it is just drawing..not cutting..it sucks for scribing ..but for drawing it's perfect.
Chris .5 and look also for a .7 mechanical pencil..that size is perfect for thick lines and as Rick mentioned about strength..this is won't break as easy.
This is a good idea for you to..buy several different brands of refill leads ..some are to easily broken as there to soft ..ive got one brand which is quite strong called Ain but also one called CTG ain't bad either 😉
Quote from: Wardukw on August 28, 2024, 08:59:29 PM
Brilliant, thanks for the heads up  :thumbsup: I will have a look in the works in town next time I am out, and see what they have got.
Just FINDING proper Dymo tape in the UK is a problem! No shops seem to sell it any longer, not even W H Smiths, so it's 'on-line' or nowhere.
Quote from: chrisonord on August 29, 2024, 12:17:59 AM
Any good stationary shop should have those pens and leads Chris ..you'll be sweet bud 😁
