avatar_MartG
1/72 Traveller 20DT Shuttle/Gig
Started by MartG, June 13, 2017, 05:20:04 PM
MartG
Another design inspired by the Traveller roleplaying game, this is a small non-starship shuttle
This is actually the first model I've built with lighting :)
First the glamour shots :)
Testing the lights - port & stbd nav lights, upper & lower strobes ( flashing LEDs ), cockpit, and engine
Before weathering
A bit dirtier :)
Murphy's 1st Law - An object at rest will be in the wrong place
Murphy's 2nd Law - An object in motion will be going in the wrong direction
Murphy's 3rd Law - For every action, there is an equal and opposite malfunction
Excellent stuff! The lighting looks really good - not overdone as some sci-fi modellers are prone to do... :thumbsup:
I keep thinking about making a Modular Cutter out of tube stock if I could find a suitable dome for the front end...
MartG
Quote from: Weaver on June 14, 2017, 01:28:26 AMI keep thinking about making a Modular Cutter out of tube stock if I could find a suitable dome for the front end...
Well you could try what I've just done for a fuel tank dome for a 1/48 Saturn V rocket I'm working on - hand sanded from high-density foam
Pic of it in progress below -
Had to use Polyfilla as normal model filler tends to dissolve the foam :)
A modular cutter is on my 'to do' list too :)
1/48?  Really?  That's over 7' tall.  Where are you going to keep it!?
Good work on the 20DT.  I fail when it comes to electricity so i'm always impressed at whose who can wrangle the stuff effectively.
Steel Penguin
nice effect on the cutter, and as zenrat said, clever on the tricity  :thumbsup:
and the Saturn V is going to look impressive as well
My gob is well and truly smacked - excellent work  :thumbsup:
Great work ! Looks awesome lit up and thanks for the detail pics  :thumbsup:
Nice work.  :thumbsup:
You do realize the hull shape is ideal for a 1st generation Eldar Falcon Grav Tank?
Just an observation...  :mellow:  <_<
