avatar_NARSES2
USAAF Photo Recce 1945
Started by NARSES2, September 05, 2012, 06:59:54 AM
You can only make them smaller unfortunately.  You'll have to save your new settings, then download the images again to make the bigger.
Don't delete the originals before you do it, delete them afterwards as photobucket gets confused.  It'll give the new photos the same name as the old one and the size settings will revert back to the old ones.
I've amended the default size (I hope) so farther posts should be larger. I'll just have to keep experimenting, can't repost onto PB at the moment I'm afraid, will try when I return home.
Quote from: pyro-manic on September 11, 2012, 08:57:02 AM
I don't use photobucket, but I would have thought so. You'll have to edit the post to change the links to ones that show the large pics.
Right I've changed my default size on PB and reposted one pic - size is a bit better I think ? Although I'll try and find something inbetween the 2
McGreig
A belated  :thumbsup: as I missed the original post for this. This scheme really suits the Griffon Spitfire (although I'm just putting the decals on a PR.XIX in a proper - eg Soviet - scheme  :wacko: )
