avatar_monkeyhanger
Whiffed Defiants
Started by monkeyhanger, March 10, 2010, 09:53:54 AM
monkeyhanger
Spurred on by Sequoiaranger's comments on my first whiff, a Defiant I've been in the loft and got:
Three Airfix Defiant
Stuff from the spares box
The aircraft are going to be:
Remove the turret, add four 20mm cannon wing guns
Keep the turret, add 40mm cannon under the wings
Remove the turret, replace the Merlin with a Sabre
Here goes:
If this is Upper Silesia, one can only wonder what Lower Silesia is like.
Remove the turret, add four 20mm cannon wing guns - yes (and BP proposed something along those lines anyway)!
Keep the turret, add 40mm cannon under the wings - you know I don't think a real version of this would get off the ground!  Drop the turret, I say!
Remove the turret, replace the Merlin with a Sabre - ooh yes - saves me having to do mine then!
;D ;D
Modelling_Mushi
... or you could re-engine it with a later model Merlin engine and the extra grunt would be able to lift a turret and pair of 40mm cannon . . .
Quote from: apophenia on March 10, 2010, 07:59:09 PM
kit' is probably right about turret weight and those Vickers. Two possibilities, substitute a lighter, two-gun turret or replace the turret with a flexible gun mount (twin Brownings or Vickers GO).
Now why dose that say "RAF Sturmovik" to me  ;D :thumbsup:
Radish
Oh I like that.
Add spats and it could become a divebomber!! :drink:
Oh I like that.....yes to the open rear gunners station...twin guns sound good....it does look a bit IL2 like.....up armour the nose n engine area...maybe as simple as externally the plate stuff like on the FW190A8 Sturmbok around the panels n an armoured windscreen....with a bigger engine......H
Started this for the LIS GB but got bogged down fixing the crappy kit engine and then ran out of time:
Anson turret and skis, basically. No, the Anson turret does NOT "just fit" as I thought it did when I started.... :rolleyes:
monkeyhanger
OK, Merlin engine isn't powerful enough and the kit's nose "leaves something to be desired". I have three spare Sabres (from the Matchbox Tempests, but as Mark IIs in the mid seventies) so how about:
Note that the tails have had to be removed, more torque from the biggger engines? So that leaves so scope for the tail ends. I'm keeping one with a Merlin, as you can see started to add the body putty........
Quote from: NARSES2 on March 11, 2010, 03:45:50 AM
My thoughts exactly!  ;D ;D
Quote from: kitbasher on March 11, 2010, 12:23:36 PM
Yes - I noted some time ago, that if you de-turret a Defiant, you get a very Stumovik look:
monkeyhanger
OK, lots of sanding to get the Sabres to fit, and then they fell off!!!! So, glue them back on, reinforce the joints, putty, sand.........
I've bought some Aeroclub Vokes filters to tidy up the Merlin engined version. Ok, not perfect but just an attempt to draw the eye away from the incorrect shape. also, these are desert aircraft, so a vokes filter would be used.
an added complication is I've just been offered 6 to 9 months work in Leicester. So, I can only carry on with portable projects except at weekends.
