CF-105 & Thundercheif Query
Started by Cobra, February 09, 2010, 07:48:07 PM
Cobra
Hey Guys, Can Anyone Tell me if the F-105  'Thundercheif' aka the 'Thud' had ever been Looked @ by the RCAF? i know the RCAF seemed to add C to Aircraft like the F-101 Voodoo and the Like and was Wondering if the F-105 would have used 'CF-105' if the Arrow Had not Been Built???? just something i was Wondering about. Thanks for Looking. Dan
I can't verify it but I believe they looked at the 105 at the same time as the F-4, when we ultimately decided on the far superior 104 !
:unsure:
anthonyp
They were Canadian, therefore, drunk  ;D
I exist to pi$$ others off!!!
Fulcrum
In the 70's(after the Arrow was cancelled), the Canadian military wanted a tactical aircraft to support the newly-formed Mobile Command(in case of deployment to Norway). The Canadian military evaluated several aircraft & prefered the F-105 Thud, but the Trudeau administration decided to go for the F-5 Freedom Fighter in the end. :rolleyes:
It would make designation very confusing if BOTH were in service at the same time ;D :o :lol: :blink:
(Arrow for air to air, with the Thud doing air to ground).
Fulcrums Forever!!!
Master Assembler
Leads to the intriguing thought of Avro Canada taking the lead on a new interceptor by fitting big delta wings to a Thud........ :wacko:
Quote from: Fulcrum on February 10, 2010, 12:19:48 AM
To add, I remember reading that the F-5 got the order because Northrop didn't have a problem having the aircraft built in Canada, whereas Republic was almost at the end of it's life.  Something like that anyway ----
Quote from: kitnut617 on February 10, 2010, 06:26:26 AM
I know Canada was in the initial phases of MRCA before leaving, but did they ever look at the Jaguar?
Quotei know the RCAF seemed to add C to Aircraft like the F-101 Voodoo and the Like and was Wondering if the F-105 would have used 'CF-105'
I know it seems like that, but it is just a little more complicated - see here.
If both the Avro and the Republic designs were in service concurrently, I believe they would have different designations - perhaps one would be the CF-105 and the other the CF-106 or something to that effect.
apophenia
#8
Since the F-105 was in competition with the Northrop F-5, it's fair to assume that the RCAF/CF designation for a successful bid by Republic would still have been CF-116.
[Note that 'CF-5' is an unofficial designation. Maybe 'CF-105' would have been used unofficially but I doubt it.]
Quote from: GTX on February 12, 2010, 01:14:36 PM
The Canadian Airforce (RCAF or CAF) numbering system makes it very difficult to add a what-if in between some existing RW aircraft, each aircraft taken on is given the next available number, the 106 is actually a CC-106 Yukon (Canadian made Britannia).  The exceptions are the recent F-18 and C-17, these are CF-188 and CC-177.
This link will show you how it works.
http://www.ody.ca/~bwalker/post_int.html
Can't help with the designation but know I have seen a profile or two here of the Thud in Candadian markings.  Check the profile areas or give Maverick a buzz.  He probably has one stored on his photobucket (but danged if I can ever find anything there).
US SIG Leader
Quote from: apophenia on February 12, 2010, 05:10:14 PM
This photo of an F-105 display model in RCAF markings was on IPMS Ottawa's site. Note the 'FH-105"  :unsure:
That's interesting isn't it? I wonder what the 'FH' stands for ?  The 'H' in CH usually means 'Helicopter'
I wouldn't read too much into the FH-105.
Note that the fake tail number is 40105 and that through much of the 1950s the RCAF
used aircraft codes that consisted of two alpha characters followed by three numerical
characters, with the three numerals being the final three digits of the tail code.
So FH-105 may just have been the Republic model shop's attempt to give that model
a Canadian identity, of course if so, they didn't understand that the code should have
looked like:
;D
Edit: also the FH code was used on USAF F-105s.
elmayerle
The Osprey Air Combat book on the F-105 lists at least two distinct proposals to Canada for F-105 variants, both including use of variants of the Iroquois engine.  I'm not sure what the differences are between the two, but the earlier one seems to be part of a common family being pitched to the UK (with Olympus), France (with a J75 since France already had the license for it), and to Germany (presumeably withthe J75).  The other one comes in as a later dash number on the basic Republic designator series for the F-105.
--Jane Wagner and Lily Tomlin
Quote from: elmayerle on February 14, 2010, 07:43:27 PM
Interesting because if I ever get around to building my Trumpeter one she will be French in the lovely "sand and chocolate" scheme  :wub:
