avatar_ysi_maniac
Spanish Buchón
Started by ysi_maniac, September 26, 2007, 08:44:16 AM
In the past, I used to think that Me-109 was not attractive and Buchón even less. But after building this model a began to appreciate its nose's lines. Now, I am seriously thinking in a second version (whiff) more aestheticaly oriented. :rolleyes: We will see. :thumbsup:
I've always thought the Buchón was a very sleek, fast looking bird and your version is gorgeous, Carlos!
:wub: :wub:
Quote from: ysi_maniac on November 19, 2009, 05:01:18 AM
Hi Gang,
What do you think about a Bf-109E (I like squared wings) with a nose of Buchón type, bouble top and squared tail fin/rudder? :rolleyes:
Martin H
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
Quote from: ysi_maniac on November 20, 2009, 11:03:58 AM
Hi Gang,
Sounds a bit like a '309 with a Merlin, I like the idea!
Sauragnmon
Or alternately for a Bubble Buchon, one could start with the Ki-100-II Bubbletop version - they were originally 605 driven, so it you modify it and clear off the radial, you should in theory be able to fit it in place - of course she'd probably have some cowling guns still potentially, or the space for them in theory.
Quote from: apophenia
Instead of lowering the '109 rear fuselage, what about raising the upper cowling Spiteful-style. That way, the canopy is raised and the pilot could sit above a larger fuel tank.
This is a very good idea!  :thumbsup: :wub:
